need more MPG's
Old Feb 16, 2008 | 06:40 PM
redsford's Avatar
redsford
need more MPG's
my '87 F150, 4.9 will not get better than 10 mpg. and loosing power climbing hills help....
Old Feb 16, 2008 | 07:03 PM
StealthWyvern's Avatar
StealthWyvern
Are you running large over sized tires with a lift? recent tune up? pulling a load? 4x2 or 4x4? CEL?
Old Feb 23, 2008 | 03:52 PM
redsford's Avatar
redsford
need more mpg's
No large tires or anything, did tune up 4 months ago before winter started. its also a 2 WD. Starts easy and idles normal yet when driving at 70 mph and climbing a hill I lose about 15 mph before I reach the top of the hill and it is not a real steep grade... just put a new clutch and brakes also...
Old Feb 23, 2008 | 05:09 PM
TheRoadVirus's Avatar
TheRoadVirus
Did your tuneup include a fuel filter? Check fuel psi and do a compression check.
Old Feb 24, 2008 | 12:38 PM
Red Diamond Ranch's Avatar
Red Diamond Ranch
Check your Cat converter and your muffler for blockage. The inards collapse sometimes and block the exhast flow.https://www.ford-trucks.com/forums/n...e=1&p=5746333#
Old Feb 24, 2008 | 12:40 PM
quicklook2's Avatar
quicklook2
use a vacuum gauge to check for a blocked exhaust system.
check plugs for fouling.
Old Feb 24, 2008 | 11:01 PM
Conanski's Avatar
Conanski
What gearing does the truck have?
What tranny?
Old Feb 24, 2008 | 11:03 PM
emiltech's Avatar
emiltech
check something simple ....tire pressure....brake adjustment...transmission shifting properly (auto)
Old Feb 25, 2008 | 12:32 AM
Animalistic's Avatar
Animalistic
That would be my guess. Jack each tire up and make sure it spins with no restance. It is amazing how much friction can be created from a bad bearing or a stuck brake.
Old Feb 25, 2008 | 12:56 AM
BChance's Avatar
BChance
need more MPG's
Don't we all?
Did it happen start right after some of the work you listed was done?
Old Feb 26, 2008 | 09:42 PM
redsford's Avatar
redsford
No it started as the temperatures started to go down, as far as the brakes and stuff, the tires spin freely and the trans is a 4 spd. also put new exhaust system in it last summer.
Old Feb 26, 2008 | 09:51 PM
quicklook2's Avatar
quicklook2
what was included in your new exhaust?
pull plugs.
use a vacuum gauge to check condition of engine.
Old Feb 26, 2008 | 11:28 PM
Kista20's Avatar
Kista20
check tire pressures both my vehicles were low because of the cold weather, dad has an 87 f150 2wd short bed 4.9 w/ 3 speed w/od, 3.55's and he gets-17-18 mpg's all the time.
Old Feb 27, 2008 | 09:29 AM
Grey89F250's Avatar
Grey89F250
I have mine figured in at about 11mpgs!! I gonna check the cat on mine. How do you check the cat? Sorry for the hijack!!
Old Feb 27, 2008 | 03:41 PM
wpinef's Avatar
wpinef
10-11 MPG with the truck in my sig
Dave
