No Go
Old Feb 16, 2008 | 02:10 PM
jim6liter's Avatar
jim6liter
No Go
Well I posted a noise a few days ago and now my truck will not even go above 1000 RPM. Any ideas? Appointment is for tuesday at the dealer.
Old Feb 16, 2008 | 09:37 PM
run6.0run's Avatar
run6.0run
Loss of power and a noise. HPOP or turbo. Could be as easy as a sensor. Looked for your noise post could not find it. Anything else, bucking, cutting out, coolant loss, smoke???????
Good luck
Old Feb 16, 2008 | 09:50 PM
jim6liter's Avatar
jim6liter
no coolant loss,no smoke,idles smooth,just wont take throttle and when you give it peddle it gets real quiet.
Old Feb 17, 2008 | 12:09 AM
bismic's Avatar
bismic
Looks like two posts on the same issue (probably because you didn't get a lot of responses on the other post). Now the other post looks like it is getting good support (if so, you may want to close this one):
https://www.ford-trucks.com/forums/7...ing-sound.html
Old Feb 19, 2008 | 10:46 PM
jim6liter's Avatar
jim6liter
http://i148.photobucket.com/albums/s...ggraybroke.jpg
okay so truck got diagnosed, oil pump went out. Just as suspected. Do these motors have a low ppressure pump and high pressure pump also? Thanks guys! I'll be back on the road soon.
Old Feb 19, 2008 | 11:04 PM
bismic's Avatar
bismic
Yes - regular oil pump for lubrication and high pressure pump, HPOP, for actuating the injectors. Glad you are getting it taken care of.
Old Feb 19, 2008 | 11:15 PM
jim6liter's Avatar
jim6liter
I'm wondering what makes these HPOPS go out? Is there something I can do to prevent this in the future? Thanks bismic
Old Feb 20, 2008 | 09:00 PM
jim6liter's Avatar
jim6liter
Okay, so got my truck back and it runs great. They removed the injector pressure oil regulator and found a hole in it with some metal from the high pressure oil pump internal damage. So they relaced those two items and all is good.
