dp instillation
Old Feb 15, 2008 | 01:51 PM
pakmor's Avatar
pakmor
dp instillation
ok so i'm tryin to install my dp and first of there was 3 10 mm bolts not, one now i'm havin alot of trouble gettin my pcm out. its like its made into the firewall or somethin, i'm about to get really pissed off, some please help.
Old Feb 15, 2008 | 02:01 PM
maevans's Avatar
maevans
Maybee this will help, http://guzzle.rbmicro.com/dptune.html
03_PSD's Avatar
03_PSD
see if this helps
Old Feb 15, 2008 | 02:02 PM
03_PSD's Avatar
03_PSD
marks faster than i...lol
Old Feb 15, 2008 | 02:05 PM
maevans's Avatar
maevans
Once you remove the mounting bolts,
It does take a little tug from the inside the truck to release the pcm from the rubber seal.
Old Feb 15, 2008 | 02:10 PM
Izzy351's Avatar
Izzy351
There is a video as well -- there is only one 10mm bolt under the hood. There are two 7mm bolts in the cab. Make sure you're disconnecting the correct connector...
Here's the video:
http://www.dieselmovies.com/view_video.php?viewkey=b0395e163467c9dae521
Old Feb 15, 2008 | 04:27 PM
MTDewX's Avatar
MTDewX
step back and take a deep breath.
go some where for a bit. take a break before you break some thing.
that is what I do at least.
Old Feb 15, 2008 | 04:32 PM
ts_stroker's Avatar
ts_stroker
you unplugged the idm. the pcm is the on beside it upagainst the fender
Old Feb 15, 2008 | 04:59 PM
badger2196's Avatar
badger2196
Yep, sounds like it's still connected to the plug on the firewall (under the hood). There's only one 10mm bolt on that connector.
Have patience - it's a little tricky to remove that thing.
