Flange tool vs Butt weld
dave
You also didn't say what type of welding you are doing, MIG, TIG, Gas. In all cases but goo TIG welding I would suggest flanging the panel.
Just my opinion.
Kenny
dave
One trick on flanging...make sure you flange the upper part. You want the flange so it is open to the bottom (lower) side of the car. Why? Easy, water goes downhill and thus will run out, if the flange lip is up, it traps water and junk allowing it to rust quicker.
Kenny
The preferred welding method would be with your MIG welder but only with shielding gas. Don't even THINK about using flux core to weld body sheet metal. Also, you will have to MIG it in a series of small tack welds jumping around all over until you have filled in all of the seams. If you just take off and start running a bead you will warp the heck out of it.
MIG it by putting a tack in a few places scattered around to hold it in place. Then put a tack halfway between the tacks, then halfway between those and so on. Once it is all done, then don't grind all of the weld off. Leave enough so that it stays together. THEN seal the weld with fiberglass reinforced plastic filler to keep it from rusting.
Good luck,
Appreciate the information of MIG welding, going to purchase the tank within next 2-3 weeks, likely get the larger, or medium size bottle; rather than purchase as I did with the oxy/acyl tanks, may rent at the start and then swap and buy smaller when majority of the welding is completed. Find as a 'do it myself backyard mechanic' the oxy/acyl tanks can go for couple years or so before they need refilling. Thanks again!
dave
If you purchase an electric welder of any kind (tig, mig, arc) you'll find that you'll use it a lot more than your oxy/acyl setup because it's much more convienent to roll the cart around, plug it in, and fire it up. You're not limited to automotive work.
I've fixed mailboxes, welded lightposts together (which saved me from digging up the old one that rusted in the middle, but the bottom was fine), repair mower decks, old metal benches, the lawn cart, wheel barrows, etc. I added an air-actuated snowplow to my riding mower, and even welded mower connecting rods together. I've made tampers (large round concrete thing with a steel handle for squashing newly turned soil), I've welded gates/railings, ride-on toys for my son, made tools and accessories for my lathe & milling machine, welded patches on rusty garage door tracks since I was too cheap to replace them. I even made plant hangers and plant hanger posts for my better half. Left-over electrical conduit or black pipe fishmouthed and the potted plants hang on that. Welded holes in the gas grill, and the list goes on and on and on.
The most fun project I've done was welding patches on the steel inground pool frame when the liner was replaced a few years ago. After the liner company removed water and old liner, they wanted to walk off the job because the steel frame looked like swiss cheese in some places. I told them to come back in 3 days, giving me the time to patch it.
What did I patch it with? Car roofes
I cut 'em off at the junkyard using a borrowed gas-powered metal cutting saw (which takes no time at all), then hammered them reasonably flat on the back patio with a block of wood and a big hammer, then cut it up and welded the smaller patches over the holes in the metal pool shell.A spool of flux core wire and about 40 flap discs later, the pool liner company installed the new foam backing and liner with no troubles at all. I probably should have used galvenized steel but the pool is moving eventually anyway so it doesn't have to survive another 60 years - which is how old the pool shell was at the time (its now 65 yrs old)
I do flanging the lazy way.... instead of drilling/punching holes for cleco's, rivets and so forth, I just make 1/8" deep flanges and clamp them together on the inside with vice grips. Then I run a bead down the length of the two flange's edge, joining the panels. To do this method the flanges have to be short - since you're welding the flange's edge. If the flanges are long the panels can vibrate and any body filler you put between them on the outside will eventually break free and fall out. That's why I recommended a 1/8" measurement - I run beads that are just about 1/8" deep. I also stitch these... meaning I weld an inch, then move 4-6" away and drop another inch bead, and continue to the end of the panel, then start over and repeat until the whole flanged seam is welded shut. This prevents panel warpage.
Metal shrinks when heated to the point where you're welding it together, so short bursts spaced far apart minimizes the "heat soak" into the material.
Once done I wirewheel the bead to remove loose slag and the sooty remains of the flux core shielding substance, and will grind off any obvious sharp edges or weird "drippings" if there are any.
Then prime and paint normally. On the outside I fill the seam with a fine body filler like "Rage Gold" and prime and paint to my liking.
