turbo install
Old Feb 15, 2008 | 09:29 AM
Rick2001's Avatar
Rick2001
turbo install
Can a stock style turbo be replaced with out disconnecting the up pipes?
Old Feb 15, 2008 | 09:32 AM
Pocket's Avatar
Pocket
The up-pipes connect to the back of the turbo, so if you are pulling the turbo, you have to disconnect that v-band clamp that holds the up-pipes to the turbine inlet. You don't have to remove any of the lower bolts for the up-pipe, such as the ones at the manifold.
Old Feb 15, 2008 | 09:34 AM
Rick2001's Avatar
Rick2001
hmm ok so I would have to replace the gasket then. Or just go ahead an do up pipes at the same time.
Old Feb 15, 2008 | 09:39 AM
Pocket's Avatar
Pocket
There is no gasket that mates the up-pipes to the turbo. There is a pin on the pipe flange that aligns to a hole on the back of the turbo, and that's about it. The donut gaskets you might be thinking of are on the bottom of the y-collector. If your turbo is already off and you suspect those donut gaskets are leaking, then you have the perfect opportunity to replace the donuts or swap out for the bellowed up-pipes. You'll see the y-collector right in front of you when you pull the turbo off.
Old Feb 15, 2008 | 10:29 AM
Rick2001's Avatar
Rick2001
ok yes that is where I was going. I do have a small up pipe leak and will do new up pipes eventually. but I need to put a turbo on this truck first.
I was not sure if that collector was part of the turbo or a seperate.
thanks fo rthe info
03_PSD
29
Feb 9, 2009 07:31 AM
airharley
Nov 19, 2008 07:42 PM
Jens
Dec 24, 2002 02:44 PM
powerstroker250
Jul 12, 2002 01:42 AM
hotrodmex
Mar 8, 2001 05:32 PM
