Pinstripe
Old 02-14-2008, 09:56 PM
jdecker88's Avatar
jdecker88
jdecker88 is offline
Pinstripe
Hey fellers,
After I got my truck I started looking really close along the body lines when I was cleaning it. I seen at one point in time it had pinstriping down the side of it, looked like the factory Ford style that just ran down the cab. I know ford didn't have pinstriping on these trucks and I was wondering where I could get some online. Would I need to find some F-150 or Excursion Pinstriping?
Thanks in advance guys.
Old 02-14-2008, 09:59 PM
jeff7825's Avatar
jeff7825
jeff7825 is offline
Are you talking about the two tone pin stripe, or a stripe that was higher than that?
Old 02-14-2008, 10:07 PM
jdecker88's Avatar
jdecker88
Upper Pinstripe, I have seen it on F-150s, some have the Lariat wrote into it.
Old 02-14-2008, 10:16 PM
jeff7825's Avatar
jeff7825
jeff7825 is offline
I guess try ebay or maybe try directfordparts. But I know for a fact that those factory stripe kits are not cheap.
Old 02-14-2008, 11:48 PM
nhill2090's Avatar
nhill2090
nhill2090 is offline
Originally Posted by jeff7825
I guess try ebay or maybe try directfordparts. But I know for fact that those factory stripe kits are not cheap.
i cant imagine they would be too easy to install either. getting it to look right and straight, that is.
Old 02-15-2008, 08:19 AM
DieselCamper01's Avatar
DieselCamper01
DieselCamper01 is offline
Look up an auto body paint supply store. They will have lots of options and way cheaper.
Old 02-15-2008, 03:20 PM
jdecker88's Avatar
jdecker88
I think that is what I will have to do, I know from Ford it is EXPENSIVE. It isn't as hard as you think to put it down Nic, I did a 25 Ft gooseneck trailer plus the neck and it wasn't that bad. Jeff, ebay was a dead hit tried it several times with no luck.
Old 02-15-2008, 03:23 PM
jeff7825's Avatar
jeff7825
jeff7825 is offline
Even if you do get a stripe kit for a 150 or other vehicle, it most likely won't match your truck colors anyway.
Old 02-15-2008, 04:03 PM
jdecker88's Avatar
jdecker88
Well the oxford white and gold trucks are the same as ours. The pinstripe I seen is two stripes of gold down the side.
Old 02-15-2008, 05:20 PM
nhill2090's Avatar
nhill2090
i would like to see someone do it, im sure if you have done it befoer it cant be too bad im just curious
Old 02-15-2008, 05:33 PM
jdecker88's Avatar
jdecker88
That took two people running that entire lenght, but it is very easy to mess up, this is with the tape pinstriping not painting it on.
Old 02-15-2008, 06:08 PM
guitarpicr's Avatar
guitarpicr
guitarpicr is offline
Went to autozone and got a kit for about $6.00 -Put it on in about45 minutes - Theres no fancy laredo writing on it but it turned out pretty good and straight. My wife liked it so much she asked me to do her car too. Even did some fancy squiggles on the ends of my truck with a little practice on a piece of scrap sheet metal.Good Luck.
Old 02-15-2008, 06:19 PM
jdecker88's Avatar
jdecker88
Could you get me some pictures up of yours Bill, I would really appricate it.
Old 02-15-2008, 06:24 PM
trash collector's Avatar
trash collector
trash collector is offline
Go to window tint shop, most of them also do pin striping.
Old 02-15-2008, 10:47 PM
guitarpicr's Avatar
guitarpicr
JD - I'll try to get some pics tomorrow if I can post them up.
FORDF100SB
06-01-2015 12:18 AM
Gater180
04-14-2015 04:52 PM
rossvt
1947 and Older Ford Trucks
03-10-2014 09:39 AM
Zookie400
Paint & Bodywork
11-01-2010 03:32 PM
jwpurl
1999 to 2016 Super Duty
09-22-2009 12:57 PM
Quick Reply: Pinstripe
