Sponsored by: Real Truck
Chevy 8.1
Old Mar 30, 2008 | 12:05 PM
  #46
jake00's Avatar
jake00
Originally Posted by redford
Keep in mind the 'burb is 1000-1500 pounds lighter than your truck. How well would your truck rin down the road if you could shave 1500 pounds of weight from it?
I think its less than that, more like 500 lbs. I try to get them weighed soon
Old Mar 30, 2008 | 04:22 PM
  #47
Remmy's Avatar
Remmy
Originally Posted by tr0y
The allison 5 speed is far and away better than the 5 speed ford trans I have now.
I'm going to have to disagree, I'm on my second truck with a Torqshift Trans (A chipped 6.0 Powerstroke & current v10) and I just traded in a 2006 Duramax with the 6-speed Allison. The Allison is Superior, but the Torqshift is right there. Both are great transmissions and are at the top of their market segment. I was amazed at how well the torqshift did even with a 450 hp turbo-diesel in front of it.
Old Mar 30, 2008 | 08:14 PM
  #48
HarleyFXDL's Avatar
HarleyFXDL
I had a 2001 Chevy with the 8.1L engine with 4.10 rear. Ran my friend who had a V-10. I passed him like he threw an anchor out of his truck. 8.1 is a beast but his V-10 was the 2V engine.
Old Mar 30, 2008 | 08:30 PM
  #49
78_79ford's Avatar
78_79ford
yeah looks like the first poster to match up the Chevy 8.1 V-8 to The Ford V-10, gave specs for the 5.4 Liter Ford V-8 instead, but that is still pretty impressive considering the Chevy has 2.7 liters on the triton V-8.
Old Mar 30, 2008 | 08:45 PM
  #50
scottman70's Avatar
scottman70
AGREED Had an 01 at work, drove it quite often and that thing hauled ****! Stronger by far than any V-10 I have ever ridden in! It was a 2500 long bed ex cab with 4.10's. Whew it accelerated fast!! It got 11 mpg if you feathered it or ran the crap out of it......... Much stonger than the V-10's, but expected since those 8 cylinders must have been large in comparison to the small pistons in the V-10! Stroke has a lot to do with it too! Don't know why GM canned it for the POS 6.0 gasser, talk about gutless!!
Old Mar 30, 2008 | 09:06 PM
  #51
pagnew's Avatar
pagnew
I disagree about the Chevy 8.1L taking out a 3V 6.8L V10. The one I went against was an 05 and we were about head to head. My truck is a 2006 4:30 Supercab 4X4.
Old Mar 30, 2008 | 09:10 PM
  #52
scottman70's Avatar
scottman70
That would be expected with the gearing advantage you had, put 4.30's behind an 8.1 and that would be a fair comparison! 4.30 would make an 8.1 go through those gears even faster....4.30 would be nice mated to an 8.1...
Old Mar 30, 2008 | 09:18 PM
  #53
capn kirk's Avatar
capn kirk
if your gonna talk about fair comaprison through gearing then you have to account for weight also so you would need to add a 1000lbs to the chevy this is if were still comparing the 8.1 to the v10 motor and trans
Old Mar 30, 2008 | 09:39 PM
  #54
pagnew's Avatar
pagnew
He had smaller diameter tires than my 275/75/18's...maybe that helped him keep up at least
Old Apr 1, 2008 | 07:59 AM
  #55
mitchntx's Avatar
mitchntx
Originally Posted by dkf
Your saying pulling the same trailer the 8.1l gasser and the PSD got 10mpg. Sorry your towing mpg #s don't sound right at all.
Update ...
I recently pulled my 10K trailer to Houston and back to DFW and got 12.5 mpg running about 65. The odometer just turned over 30K miles. The empty, combined mileage hasn't changed, though.
The internet rumor about these motors getting better with age appears to be true.
Old Apr 1, 2008 | 08:05 AM
  #56
dkf's Avatar
dkf
Originally Posted by mitchntx
Update ...
Hopefully it will keep getting better. With diesel costing what it does (Gas too) it can really put a hurtin on a guy.
The warmer weather should help mpg also.
Old Apr 1, 2008 | 08:07 AM
  #57
dkf's Avatar
dkf
There is minimal difference between 4:10s and 4:30s. For some reason chevy puts tiny tires on their trucks compared to Ford some the final drive ratio more than likely still favored the chevy.
Old Apr 1, 2008 | 02:04 PM
  #58
HarleyFXDL's Avatar
HarleyFXDL
I'm running 265/75/16 on my Chevy with the 4:10 L/S and it will bbq the rear tires with the 8.1 engine. My 06 F-350 has the 5.4 and it's not even close to the Chevy. My friend with the 2V V-10 is a 4x2 as opposed to my 4x4. He's still scratching his with disbelief how my Chevy stomped him.
Old Apr 1, 2008 | 03:37 PM
  #59
pagnew's Avatar
pagnew
To bad for your friend - generally the 8.1L 4X4 Chevy and the 3V V10 is a wash. He must have a first generation 2V V10 with 3:73's or somethin' or he doesn't have a clue how to race....
Old Apr 1, 2008 | 03:44 PM
  #60
dkf's Avatar
dkf
I could BBQ the tires on my V10 too. Hell you can do bbq the tires on a little ricer too.
The 8.1l has long been discontinued in the 2500 and 3500.
