Offroad & 4x4
Bw 1356
Old Feb 14, 2008 | 03:45 PM
Matt99362's Avatar
Matt99362
Bw 1356
Hello everyone,
I'm just starting the build up on my 89 FSB and I'm curious if anyone has had any problems with their BW 1356 transfercase. From what I have read they have only one real inherant flaw, which would be the pump-stop area of the case allowing the oil pump housing to begin to spin freely, instead of being held stationary, as it should be. I'm going to be running 35" tires with 6" of lift, possible more depending on any rubbing issues.
Before you all respond with the upgrade choices, please understand that this is going to be a budget build. I'm not rich, and I'm not in an area where we have u-pull it yards. I just want to know if anyone has anything bad to say about the 1356 itself.
Thank you all. I appreciate your input.
Old Feb 14, 2008 | 04:00 PM
MBBFord's Avatar
MBBFord
For someone wanting a extream strength t-case on the cheap, then the NP205 would be it.
For what you need, I'd say stick with the BW. Should be fine with 35s.
Old Feb 14, 2008 | 04:32 PM
projectnitemare's Avatar
projectnitemare
The pump problem is the only real major issue. Prettyy much any other problems you would find would be wear and tear issues or you breaking it from being too hard on it. For what you have the 1356 will do fine. If you feel you need something stronger the NP205 is the strongest t-case in stock form.
Matt
Old Feb 14, 2008 | 05:29 PM
Matt99362's Avatar
Matt99362
Thanks guys, I appreciate the input. I'm not a hard core wheeler, just need something to get to the cabin in the snow.
Old Feb 14, 2008 | 05:40 PM
tjc transport's Avatar
tjc transport
i ain't rite
i killed a 1356 in my 88 due to too much power, and 100,000 miles of severe abuse over 15 years.
but i also replaced it with a 1356, cause if it lasted 15 years with what i put it through with the 5 speed, it will last forever with the automatic trans.
nstueve
Jan 26, 2011 09:41 AM
jim repairs
Feb 2, 2008 06:15 PM
Rediranch_too
Dec 11, 2007 03:33 PM
masseysbronco
1978 - 1996 Big Bronco
Apr 11, 2006 08:38 PM
FordPerf300
15
Jun 8, 2003 11:08 PM
