we are trying to get the hood on my 54 adjusted.we have adjusted the hood hinges and fenders but still need to get 1/4 inch on front of hood.hood needs to go to the left as you sit in the truck.will adjusting the hood rods make any difference pulling the front right or left?or do they just adjust the rear of the hood? also am I right that to much pressure on the hood latch will bring the back of the hood up?
Try adjusting the rods to see if it makes a diff. One thing I know for sure. It is nearly impossible to get a perfect hood fit on the 53-56's. I had to elongate the hinge mounting holes to get a decent fit on my 55.
Have not tried this but... I was approcahed by a ol'timer one day who wanted to look at my old truck, He said he worked at a Ford dealership in his day. He told me the proper way to align the hood on my 55 was to innitially have it off the truck lying on the ground painted side up just as if it were mounted on the truck. He said then adjust the rods so that all 4 corners touch the ground. then and only then can you get it adjusted properly on the truck. Seemed logical to me.
Rick
you'll be suprised what you can learn if you just listen
thanks for the help,Sometimes we are are own worst enemys,after spending 4 hours trying to figure out how to adjust the hood it dawned on me I have a original shop manual for this truck,there are two pages on hood adjustment.maybe I should read the directions.It makes me feel so dumb.
