Temp and Fuel Guages
Old Feb 13, 2008 | 09:29 PM
c-how's Avatar
c-how
I have a 2000 Excursion with 6.8L. About two months ago the outside temperature gauge in the overhead message center and the fuel gauge in the dash started malfunctioning. The fuel gauge is stuck on full and the outside temperature gauge reads about 40 degrees less than it really is. For example according to the gauge the air temp outside is 42 degrees but I know it is at least 85 to 90 degrees.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Are these two gauges linked by a common fuse or relay? <o></o>
<o></o>
Just before these gauges started malfunctioning I had a tie rod replaced on the vehicle. I really do not understand how this could be linked to the problems so think it is a coincidence.<o></o>
<o></o>
Any ideas?<o></o>
<o></o>
Thanks<o></o>
Al
Old Sep 13, 2012 | 09:10 PM
Oceanside Mike's Avatar
Oceanside Mike
2001 excursion 6.8 fuel gauge reads full, ambient air temp reads low by 20 degrees @ same time??
mt54
Mar 1, 2008 06:52 AM
DOHC330MustangGT
62
May 29, 2007 10:53 PM
dbw70
May 14, 2007 06:23 PM
jd111404
Apr 21, 2007 12:25 PM
pforr
Feb 23, 2007 01:38 AM
