Sponsored by: Real Truck
code 27 on my airbag
Old Feb 13, 2008 | 09:11 PM
95frd's Avatar
95frd
my 03'f-250 reg cab is bring up a code 27
is it for the passenger air back on/off light? it doesnt come on when i turn the key to on, nor when i turn it off.
could it have come unplugged?
Old Feb 13, 2008 | 10:02 PM
nzirbel's Avatar
nzirbel
no, the bulb in it has burned out. I took the module apart and replaced mine with a 12v diode for less than $2.00 and about 15 minutes time. Just takes a soldering iron to heat up the solder to get the bulb out and the diode in.
Old Feb 13, 2008 | 11:53 PM
cartmanea's Avatar
cartmanea
Code 27 indicates the passenger airbag is disabled. Does it still flash 27 when the key switch is on? If so, something may be disconnected.
Old Feb 13, 2008 | 11:55 PM
95frd's Avatar
95frd
yeah as soon as you turn the key on, or at least start it, it flashes the code like 3 or 4 times, then the airbag light just stays on. the off like for the passenger side doesnt come on no matter what i do
Old Feb 14, 2008 | 12:18 AM
cartmanea's Avatar
cartmanea
But if the passenger side airbag switch is turned on does it still flash the code?
Old Feb 14, 2008 | 12:48 AM
95frd's Avatar
95frd
i believe so. i will try it in the morning when i leave and let you know
Old Feb 14, 2008 | 07:13 AM
projectSHO89's Avatar
projectSHO89
Replace the bulb in the PAD assembly. It's burned out.
Steve
Old Feb 14, 2008 | 05:09 PM
nzirbel's Avatar
nzirbel
Sorry, 12v LED. They have them at radio shack. The factory bulb is white with an orange cover on it. I put in a red LED because it's whats they had.
Old Feb 14, 2008 | 11:19 PM
Green_Monster's Avatar
Green_Monster
if you install an led you will need to install a resistor as well. The parts can bbe had at radio shack like nz said. If you screw it up powestrokeshop.com sells the part for like $50
7700Rob
1997 - 2003 F150
16
Feb 16, 2015 03:07 PM
bigjons
1997 - 2003 F150
Nov 26, 2011 03:14 PM
naiku
1997 - 2003 F150
Mar 11, 2011 06:34 PM
bigtim1985
1983 - 2012 Ranger & B-Series
Feb 8, 2007 09:19 AM
