Sponsored by: Kumho
junk yard trip
Old Feb 13, 2008 | 05:25 PM
harvy's Avatar
harvy
Question junk yard trip
looking for a set of wheels for my 89 f100. anyone know what wouid fit?
Old Feb 13, 2008 | 06:21 PM
Sycostang67's Avatar
Sycostang67
Need a little clarifiation here. Is your truck an 89 F-150 or an 80 F-100? They stopped making the F-100 in 83 and some of them had a different bolt pattern than the F-150's
Old Feb 13, 2008 | 06:51 PM
adeese_660's Avatar
adeese_660
Either way,they are the same wheels,weather its a 89 F150 or 80 F100,they both came stock with 15X6 wheels with the 5 on 5 1/2 bolt pattern.They are the same bolt pattern as most of the Jeeps also.BUT,for a couple of years on the F100 they DID make a differant bolt pattern on the truck they called the 4X2.I looked at your profile and saw you have an 82 F100,so if it is not the 4X2,you should be able to find tons of stock wheels that fit it.The 4X2 should be a 5 on 4 1/2 bolt pattern if I remember correctly.Hope this helps.
Old Feb 14, 2008 | 01:31 AM
harvy's Avatar
harvy
i ment 1982
Old Feb 14, 2008 | 03:54 AM
adeese_660's Avatar
adeese_660
Yea,I looked at your profile and saw you had an 82,so what I posted above still stands.
Old Feb 14, 2008 | 07:23 AM
Sycostang67
Thats what I was getting at. The larger pattern, 5x5.5 is the same as most 1/2 ton dodge trucks as well. If you have the smaller 5x4.5 pattern, thats the same as mustangs, rangers, jeeps, and mopar cars. Thats a few more options for your JY scrounging.
I dont think they made a 4wd F-100, I have never seen one anyhow. I had a 2wd 83 F-100 with the 5x5.5 wheels, but I did meet a few F-100 owners with the smaller pattern.
Old Feb 15, 2008 | 08:13 PM
tomcasino's Avatar
tomcasino
My friend had a 1973 F100 4x4. If I remember correctly it had a single speed transfer case. 5 x 5 1/2 (4x4) rims will fit 1/2 ton Fords and Jeep CJ's. It's the center hole size that differs between 4x4 and 4x2 on the Fords
Old Feb 16, 2008 | 11:04 AM
mhg's Avatar
mhg
remember, before unleaded gas there was no f150
yes there is 4x4 f100
Old Feb 16, 2008 | 04:42 PM
adeese_660's Avatar
adeese_660
Yep,I think the first F150 was in 75 if I remember right.
Old Feb 17, 2008 | 02:07 AM
Sycostang67
In the 80-86 body style?
Old Feb 17, 2008 | 03:46 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Either way,they are the same wheels, NO, THEY ARE NOT!! whether its a 89 F150 or 80 F100, they both came stock with 15X6 wheels with the 5 on 5 1/2 bolt pattern. They are the same bolt pattern as most of the Jeeps also. BUT,for a couple of years on the F100 they DID make a different bolt pattern on the truck they called the 4X2. I looked at your profile and saw you have an 82 F100 so if it is not the 4X2, you should be able to find tons of stock wheels that fit it. The 4X2 should be a 5 on 4 1/2 bolt pattern if I remember correctly. Hope this helps.
The correct information.
1948/1952 F1 / 1953/79 F100 / 1975/96 F150 = 5 X 5.50 bolt pattern.
1980/82 F100 = 5 X 4.50 bolt pattern (because of brake caliper clearance, passenger car wheels with the 4.50" bolt circle WILL NOT fit).
1983 F100 = some have 4.50" some have 5.50" bolt pattern.
No 1980/83 F100's were offered with 4WD.
These trucks have different: suspension, springs, shocks, brakes, swiss cheese frames than like F150's do.
The 9" rear axle has smaller diameter 31 splined axle shafts (2 1/4") than like F150's (2 3/4") do.
Ford advertised the 1980/83 F100's originally as a LIGHT TRUCK. Very few accessories were available. 302 V8's or 300 6's, no super or crew cabs...just regular cabs only.
Last F100 = 1983 - replaced by the Ranger.
Old Feb 17, 2008 | 11:53 AM
harvy's Avatar
harvy
my 82 has 5x5.5
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
