Push Pull Cable
Old Feb 13, 2008 | 03:18 PM
fordmudder99's Avatar
fordmudder99
Push Pull Cable
I was wonering if anybody has used a push pull cable for their clutch before. i have herd a little about them but wanted to know that they really worked in that situation. Oh by the way im tryin to use it an a 78 f150 with a 83 cab and bed. let me know thank you
Old Feb 15, 2008 | 10:22 PM
rusty7983's Avatar
rusty7983
probably not. you would have to be rear strong to pull /push that clutch in and out.
Old Feb 16, 2008 | 10:38 AM
mhg's Avatar
mhg
never heard of it but with a lever long enough it will work
why would you want to do this
it will make long red lites a pain in the biceps
Old Feb 16, 2008 | 11:59 AM
Drac's Avatar
Drac
Save the old ones
Think the later '80's trucks used the Hydraulic clutch. Check out a junk yard to get the whole ball of wax - pedal to the bell housing. It should fit in the '83 cab.
Shawn
Old Feb 16, 2008 | 03:49 PM
fordmudder99
thanks for all the input so far guys still not sure what im gonna do. if i use the push pull cable it will be hooked up to the pedel no arms needed
Old Feb 16, 2008 | 06:49 PM
mhg's Avatar
mhg
ok now I see the light duhhh
they used a cable systen in the cars, mustangs,
they have a rachet sys. for auto adj.
after market makes a quadrant to replace the rachet as
the rachet does not work well with a stiff clutch
should be easy to swap one over
Old Feb 16, 2008 | 06:56 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Medium duty GMC topkicks use a push-pull cable.
rhoward
Aug 25, 2014 06:38 PM
michaelshewkin
Jan 21, 2014 06:51 PM
alchemist1
Mar 10, 2013 03:41 AM
JCastellaw
1966 - 1977 Early Broncos
Jan 17, 2008 01:16 PM
edean37
May 29, 2003 08:48 PM
