Brake problem...
Old Feb 13, 2008 | 07:59 AM
tibailey's Avatar
tibailey
Brake problem...
On my 1999 Ford Ex. I'll get a pulsing coming from the left front brake and the stopping is not good (takes some extra push on the brake pedel). This only occurs, thank God, at low low speed. Had the master cyl. replaced about 6 mos. ago and the dealer said I have another year to two on the calipers and pads. the vehicle is making no other brake sounds.
Old Feb 13, 2008 | 08:56 AM
mason's Avatar
mason
Could be the rotor. Relatively cheap and simple to replace.
Mason
Old Feb 13, 2008 | 01:21 PM
marragtop's Avatar
marragtop
How do you know it's the left front and not the right side or both? If it is the rotor, consider replacing or turning both sides. Also, inspect the pads.
Old Feb 27, 2008 | 03:37 PM
EJJM's Avatar
EJJM
try bleeding the system, air in the system makes that pulsing feeling and needs the extra push on the pedal, pumping the pedal.
WOFP
Jan 8, 2014 08:38 AM
Duckmang
Jul 3, 2013 01:13 AM
Bruker
General Automotive Discussion
Jan 4, 2010 09:05 AM
blueoval66
Nov 3, 2005 08:43 PM
JRFX4
2004 - 2008 F150
Dec 18, 2004 09:52 AM
