Overdrive ratio 2002 E-450?
Old Feb 13, 2008 | 06:43 AM
e-450's Avatar
e-450
I am trying to find the OD ratio for my 2002 E-450. Any sources?
Thanks,
Bates
Old Feb 13, 2008 | 07:16 AM
Ultraute's Avatar
Ultraute
0.70 to 1 (4r100)
You can find all the specs with the articles/specs tab up at the top of the page.
Old Feb 13, 2008 | 07:40 AM
e-450's Avatar
e-450
Thanks,
I didnt see the 'specs' box of to the side.
.70 OD....
Old Feb 13, 2008 | 04:53 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's 0.712:1.
Old Feb 13, 2008 | 05:02 PM
e-450's Avatar
e-450
Its good to know the correct ratio, thanks.
You dont happen to know what RPM is the sweet spot for fuel mileage for a 7.3 is? 2000 rpm has been suggested. If thats the real rpm goal at a cruise speed of 60 mph, my 225/75 tires have me damn close.
So why do i get 10 mpg???
Old Feb 13, 2008 | 09:03 PM
Ultraute's Avatar
Ultraute
A little more info on your vehicle please Bates.
E-450 what,,,,cube van, Motor home, Flat bed, What? DRW? GVRW?
10 MPG on an '02 7.3L TD does not sound right.
Old Feb 13, 2008 | 09:17 PM
e-450's Avatar
e-450
2002 E-450 Cube Van 80K miles, regularly serviced.
I bought the van used about 2 years ago for my business. I am the only driver.
I had a F-350 PSD prior to the E-450. The F-350 always got 14 mpg or so, I figured the E-450 would gett at least 12 mpg, it never has.
Van is operated carrying around 1500 pounds of equipment at most times. Occasionally I go to jobs with my water tanks full which adds 4000 pounds (500 gallons)
Oddly enough the mileage only drops about 1/2 mpg carrying a full load of water.
The best mileage I ever got was 11.1 mpg after driving at 50 mph or below, babying the throttle, carrying minumum wieght. So the MPG spread is 10 to 11.1.
I agree, something aint right.
The van runs fine, typical bad glow plug cold start issues, HPOP oil lines leak (I just ordered parts to fix both of these problems)
Tires/engine RPMs is about all I can think of.
Ideas? Man I would love some advice that would fix this van.
Old Feb 14, 2008 | 10:11 AM
Clubwagon's Avatar
Clubwagon
Well, it sounds to me like its running rich. While I don't know alot about the 02 diesels specifically, injector pump timing or maybe a boost leak would be my first throughts.
Steve
'95 Clubwagon XLT
Old Feb 14, 2008 | 06:42 PM
Ultraute's Avatar
Ultraute
Not unlike Steve (Clubwagon), I don't know squat about diesels.
Have you checked with the fine folks in the 7.3 TD forum?
They should have a better idea what's going on.
Rob.
VRC9170
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 13, 2012 09:28 PM
Curt Bates
Jan 27, 2012 01:09 PM
VRC9170
Aug 2, 2011 06:04 AM
e-450
26
Feb 15, 2008 10:11 AM
e-450
18
Feb 12, 2008 10:29 AM
