shuddering with less power....
Old Dec 10, 2008 | 05:50 PM
GrizzlyPiet's Avatar
GrizzlyPiet
I dont know about the snap on, but i isolated it without the use of a scanner.
I was able to find the weak/non firing injector.
read this thread - https://www.ford-trucks.com/forums/7...ml#post6688276
I did end up buying an AE scantool so that i can buzz test them to find the bad one, that's how i found the weak one causing the same symptoms - If your scanner can do a buzz test then you may be able to tell which injector is not working correctly
Hope this helps,
Old Dec 10, 2008 | 07:43 PM
afonda's Avatar
afonda
my truck has a similar sensation when under heavy acceleration from a stand still such as a stoplight.
Naked squirrel
6.7L Power Stroke Diesel
13
Oct 8, 2013 08:08 PM
geodody
19
Jan 28, 2013 05:03 PM
kdv
45
Nov 22, 2010 06:09 PM
bentcipher
Oct 23, 2010 10:29 PM
aballard
Feb 3, 2006 07:19 AM
