Offroad & 4x4
Additional load capacity provided by add-a-leafs?
Old Feb 12, 2008 | 10:09 AM
ghunt's Avatar
ghunt
Does anyone know how much additional load capacity you get from front add-a-leafs on an '87-97 F250 HD?
Got some cheap off ebay, would like to run them to level the front, but I'm not sure since I've heard it makes the ride really rough.
Old Feb 12, 2008 | 10:37 AM
75F350's Avatar
75F350
Lots of variables here since many AAL's may have a different thickness and different rates. Really a "crap shoot" here.
By adding additional rate to your TTB front suspension, you will have to align the truck again since you will change the caster when you lift it. You will also affect the ride. AAL's will make an already stiff ride even worse.
Maybe consider this;
http://www.sky-manufacturing.com/
click on Ford/dodge on the left to view the shackle reverse for your truck.
Old Feb 12, 2008 | 02:53 PM
ghunt's Avatar
ghunt
I've seen that shackle reverse before, and while it looks like a quality setup and it's fairly inexpensive, I'm not looking to lift the truck 3" because then I'd need TTB drop brackets too.
Ah well, maybe I'll leave it alone. It already needs new front springs anyway.
Old Feb 12, 2008 | 03:26 PM
75F350's Avatar
75F350
I re-read my reply above and neede to type "Camber" and not caster. Camber will change, and not caster, but you get the idea.
Maybe if the springs are shot, you could have them re-built. Might be cheaper and better in the long run.
Old Feb 12, 2008 | 04:12 PM
magusjinx's Avatar
magusjinx
Also be careful about how much of an increase in load you do ... Remember that you are not beefing up the bearings ... You can only haul so much for so long before they wear out ... Don't wear them out too soon ...
Old Feb 12, 2008 | 10:07 PM
ghunt's Avatar
ghunt
I can get new front leafs for $250. I'm probably going that route.
Old Feb 14, 2008 | 12:14 AM
FordPickMeUp's Avatar
FordPickMeUp
i added add a leafs to the front of my 97 f 350 work truck and man it rides hard now.you will really feel every pot hole in the street.I should know get ready for a stiff ride with no spring in your thing.As far as additional load capacity im not really sure.
Jacob Bush
Aug 6, 2015 02:27 PM
BigD7575
20
Jun 5, 2013 01:39 PM
minnesotafisherman
47
Oct 4, 2012 01:52 PM
Jayme Duty
36
Mar 6, 2010 01:29 AM
jessfactor
Jun 25, 2004 05:38 PM
