05 power window switch removal
Old Feb 12, 2008 | 09:09 AM
ASR GUNS's Avatar
ASR GUNS
I know I have asked this before but never gotten a reply,
How do I remove the bezel that holds the switch in the door?
i need to replace the pass side both front and back,
F150 I'm not sure of the cab name but it has the smaller doors that swing the oposite way.
Old Feb 13, 2008 | 09:23 AM
ASR GUNS's Avatar
ASR GUNS
Question
Knowone has done this before?
Old Feb 13, 2008 | 09:40 AM
SteveVFX4's Avatar
SteveVFX4
yeah, it's easy, the bezel pops off of the door panel. You could remove your speaker grill first if you want. I am able to do it by hand using my fingernails for leverage. But you can use a small flat head screwdriver, but be careful to not to scratch the grill or door panel.
Old Dec 11, 2009 | 06:23 PM
lonewolf8's Avatar
lonewolf8
I have the same problem with my 2005 f150 FX4 driver side window switch. But my switches have no bezel to remove. Can't find any screws or a seem that would look to pull apart. Is there any instruction?
Old Dec 11, 2009 | 09:53 PM
Greg B's Avatar
Greg B
Same as Passenger side. The top of arm rest around switches pops off at the seam on the sides and switches are right there. Did the driver side on my 06 in about 15 minutes last fall. Seems to be an recurring problem on these trucks from what my dealership parts manager says.
Old Dec 12, 2009 | 12:51 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
As stated easy to pop off but pricey to replace window switches $100 a pop at ford
door lock switch $ 36
Looks the same inside getting shafted by ford
i had to change 3 last month
the price is in Ontario Canada what are they in USA.
go to Pittsburgh quite a bit may be cheaper to by there ?? any one got price's at ford USA
Old Dec 12, 2009 | 03:18 PM
Greg B's Avatar
Greg B
I payed $63 US. That included a 25% discount. I'd try one of the sponsors on this site for Ford parts. Canadian/US should be about the same once the exchange rate is factored in.
mikeb2
Aug 11, 2019 11:18 PM
wnc05ford51K
Escape & Escape Hybrid
Feb 7, 2017 07:07 AM
brabey
1997 - 2003 F150
Oct 9, 2015 04:46 PM
jjs2032
Apr 22, 2008 08:27 AM
WXboy
1983 - 2012 Ranger & B-Series
Feb 9, 2003 10:52 PM
