Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
05 Door panel
Old Feb 5, 2017 | 04:49 PM
wnc05ford51K's Avatar
wnc05ford51K
05 Door panel
I need to find a diagram of the door panel on the drivers front door. Need to see how to remove the switch bezel to check the power window switches.
Old Feb 5, 2017 | 06:52 PM
scott91370's Avatar
scott91370
The bezel will pop off if you gently pry it. I don't think there will be enough wire inside though to pull it out for testing. Removing the panel would probably be your best bet. It is just a few screws then pop the plastic retainers loose.
Old Feb 7, 2017 | 07:07 AM
Magister's Avatar
Magister
If it's any help, I've seen Youtubes for mirror replacement that show how to pop off the door cover.
Good luck!
kris101966
2004 - 2008 F150
Jan 28, 2008 07:08 PM
bnuvp
May 22, 2007 10:00 AM
superdutyquest
Jan 4, 2006 11:06 PM
Aztrainer
Jul 10, 2005 07:48 AM
sfd4
May 12, 2004 04:24 PM
