Crewcab Only Thread.
  #826
Old 01-22-2010, 04:06 AM
Broncoholic1's Avatar
Broncoholic1
Broncoholic1 is offline
Originally Posted by andyort
Im new FTE I would like to know what the best type of drip rail sealer is. I am starting my restore next week. There is no rust on this thing and i am putting all the best parts and do dads i can find on it. Any advice. Im not sure i posted on the right page if im not would you guys give send me to the right one.
Not really the right place but here ya go Andy:
Welcome to FTE, it is a nice place to visit...
Just dig around there is allot of good tech places on here.
Google Image Result for http://www.repaintsupply.com/prod_images_blowup/8307.jpg
  #827
Old 01-22-2010, 01:32 PM
andyort's Avatar
andyort
andyort is offline
the 73 chop
Well hit me back and give me a heads up on what pictures you want exactly i havnt torn the front end or the motor out of this thing yet. Ill do my best to post a few pics today. Steering gear box or radiator or both.
  #828
Old 01-22-2010, 02:56 PM
pha7env's Avatar
pha7env
pha7env is offline
what is the year break on the cab sections that dilineates different crew cab parts. For instance, if i have a 74 parts truck, will the cab parts fit my 76 or 79. Will parts off of a 71 fit a 74 or 76?
  #829
Old 01-22-2010, 02:57 PM
pha7env's Avatar
pha7env
pha7env is offline
Can i take a crew cab section and put it on a single cab, long bed and chop the bed to shorten and fit?
  #830
Old 01-22-2010, 03:26 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
78_f800crewcab4x4 is offline
Well this IS the right thread, since sealing driprails a major part of keeping the crews alive, use eastwood company non hardening black seam sealer in the tube, clean up the area, let dry, then use it like caulk, then neatly tool it into place, prime then paint.
  #831
Old 01-22-2010, 03:27 PM
lostinfords's Avatar
lostinfords
lostinfords is offline
77 cc frame
74 cc frame...you can see where winch bumper was added and extended the original frame
78/79 frame you can se how the ends are different as well as holes on the side of frame
  #832
Old 01-22-2010, 03:34 PM
78_f800crewcab4x4
Originally Posted by Cowboynando
Ok, so I bought a '73 CC a while back and have been using a '78 F-150 for a donor. Well the previous owner has Hacked the h*ll out of the truck,
Specifically the front end. The previous owner had put a 6.9 diesel in it, anyway at the moment I am trying to put the radiator mount (front clip) in the '73 from the '78 but it apears that he cut the frame and welded in lower mounts to the outside of the frame....so the front clip wont match up. I believe this was done in part because he used a different steering gear box. It's a mess! Does anyone have pic's of what it should look like? Are the lower mounts for the radiator support centered in the front part of the frame? It looks to me like they were, but the previous owner torched the frame out. I think I am going to have to box the frame, and start over. Any thoughts?
yes, bolt your entire front clip to the cab, then support the rad support in the right place. go to a pick-a-part and hack the front section of a frame off a donor truck with a sawzall (allow for extra), then graft it on in the right place so that everything lines up. weld it up, grind with a flap disk, then it should look like new.
  #833
Old 01-22-2010, 03:40 PM
78_f800crewcab4x4
yes. 73-79 cab is identical. save for some different mounting locations between single cabs on the frame. 73-79 f350 chassis are very similar. f250 frames im not sure.
  #834
Old 01-22-2010, 03:48 PM
78_f800crewcab4x4
Originally Posted by crazyredneckanyhow
Hey F800 you got a 460 in that silver monster? What kind of speeds you run on the interstate?
hah! yes an internally STOCK brand new '73 460. going into a c-6 then directly into a t136-127 2-1/2 ton t-case, then into full width 5 ton rockwells with rims made from 1/2 inch thick plate, and 48" XL's. the amount of driveline power absorbsion is astronomical, so i go about 40 down hill. I am planning for a detroit diesel or cat engine in the future though. until then i got some 40" XL's to throw on it.
  #835
Old 01-22-2010, 03:51 PM
pha7env's Avatar
pha7env
pha7env is offline
I believe Ford did that because the early 4wds were built on 2wd frames that narrowed in front to make fords truck turn sharper than the chevy. As 4wd became more accepted, frames were designed specifically for them in order to lower the center of gravity to make the trucks more tow friendly, less likely to roll and easier to enter.
  #836
Old 01-22-2010, 03:57 PM
78_f800crewcab4x4
Originally Posted by pvillebo
The reason I asked is because you are in the 1973-1979 F100 and larger F-Series trucks > crewcab only thread.You got the crewcab part right now get the years right and you will have a better chance of getting your question answered.
How is it possible that in a list of threads BY YEAR, that he don't notice the YEAR part? like a '96 has anything to do with a '79??
  #837
Old 01-22-2010, 04:21 PM
kentuckycrew's Avatar
kentuckycrew
kentuckycrew is offline
yes thats what im doing, your bed is going to be about 5'. You will also have to fab some back cab mounts
  #838
Old 01-22-2010, 08:00 PM
pha7env's Avatar
pha7env
pha7env is offline
I can do that. I've got an early 70's crew i've spotted in a Nebraska junk yard. Should not have much rust. The owner said look and make an offer. We'll see. I'll let ya'll know! thanks a lot!
  #839
Old 01-23-2010, 02:29 PM
jay54f100's Avatar
jay54f100
jay54f100 is offline
Awsome thread keep up the good work.
  #840
Old 01-23-2010, 02:53 PM
76f350spercamprspeal's Avatar
76f350spercamprspeal is offline
Here's some eye candy for ya guys:
Quick Reply: Crewcab Only Thread.
