Axle Swap
Old Feb 11, 2008 | 03:19 PM
jeddi03's Avatar
jeddi03
Axle Swap
I have a 77 F-100 2WD and I am not a huge fan of the IFS. Is there a axle swap kit to put in a solid front? If not, what other vehicle's axle would be the correct size to install?
Old Feb 11, 2008 | 03:40 PM
MBBFord's Avatar
MBBFord
Hold on......
The Front end is a I-beam front end.
If you put a solid axle up front/which is very possible, but time consuming and requires some fabing.
Then what will you do.... are you saying you want a 4wd conversion?....
Then you'll need a transfer case, new driveshafts.
Old Feb 11, 2008 | 04:46 PM
masterbeavis's Avatar
masterbeavis
I think he wants a monobeam, not twin I beam. It still is going to be a pain in the neck..... You'll have to either use parts from a 66 and older ford (and convert from drum brakes) or get creative (and open your wallet.)
Old Feb 11, 2008 | 07:50 PM
Pickupmanx2's Avatar
Pickupmanx2
Actually Masterbeav, it would have to be 64 and older, Ford introduced the TIB in 65,
And welcome Jeddi, but your best bet is to freshen up your front end with new bushing and kingpins, and tie-rods, and you will have the most DURABLE IFS ever made, for approx $300 it will drive like new.
Old Feb 11, 2008 | 08:33 PM
hp246's Avatar
hp246
Always wondered if a Mustang II front end would work?
Pablo-UA
1983 - 2012 Ranger & B-Series
Dec 3, 2014 02:38 PM
Schickel
May 5, 2013 06:34 PM
Powermonger
Sep 29, 2011 06:35 AM
rampus
Mar 14, 2011 01:01 AM
mudinford
Offroad & 4x4
Aug 4, 2000 11:55 PM
