Someone here must have used JC Whitney semi generic window channel and bottom seal on there F-1. Does anyone know what fits/works? I am converting to a one piece side window, and I need the channel. There are about a million choices for channel as well as one side pcs. for the bottom. If someone knows what works/fits I would appreciate not learning the hard way.
Thanks,
CHAZ
Thanks,
CHAZ
JCW used to send out samples (small sections) of their channels & seals. You might check to see if they still do.
Robert
I would simply go to the local glass shop ( auto ) and buy a length from them. A full strip costs to much to ship anyway due to oversize, unless they curl it into a flat coil.
Stuff is cheap and they have the wipers as well ( cat whiskers) in lengths.
I don't know where you are located but Auto Fair is in Charlotte, NC in April and Vintage Glass in Georgia will be there. They have all the parts you need to convert to one piece glass. Also check out web site at vintageglass.com.
