Low Oil Pressure
Old Feb 10, 2008 | 01:31 PM
2mortime's Avatar
2mortime
Exclamation Low Oil Pressure
2000 Exp. - 4.6L - 156,000 mi.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Problem: Low oil pressure light comes on and oil gauge drops to zero. Read several post and started with having the oil-sending unit checked; it was good. Firestone did this. They charged a $105.00. They said that was as far as they would go. Then I took it to the Ford Dealer. For $88, they told me I needed a new engine by just doing a diagnostic.
They inform me that their mechanic said that gunk was probably throughout the engine and with the mileage on the vehicle it would be less costly to replace the engine. I couldn’t believe this. So a friend and I used engine flush twice and it corrected the problem for a month. It started back today. Does anyone have a suggest on how to proceed without replacing the engine?
Thanks in advance!
Old Feb 10, 2008 | 02:00 PM
madsonp's Avatar
madsonp
You may have plugged up your oil pressure sensor when doing the flush. How does it sound when it's running ?
Old Feb 10, 2008 | 03:36 PM
2mortime's Avatar
2mortime
Sound Fine! I do not hear the typical clattering of valves when there is no oil. However, normally when this occurs I would immediately find a place to stop and shut the engine down. This time I continue to drive. It was approx. 1 ½ miles from home. The gauge would cycled through the trip home, may six to eight time. Coming on and going off. Sometimes it seems to be associated with accelerating. Weird!
Old Feb 10, 2008 | 04:48 PM
2mortime's Avatar
2mortime
Can anyone tell me were the oil pressure sensor is located?
Old Feb 10, 2008 | 05:09 PM
FTE Herman's Avatar
FTE Herman
I don't recall where the sensor is specifically; however, I can tell you that I was at my dealership a couple weeks back and they were putting a motor in to an Expy. I asked what was wrong and they said motor sludge due to lack of regular oild changes.
So, there was nothing inherently wrong with the motor, but the expense to disassemble and clean was greater than just putting a new unit in.
If it is a sensor problem and you can repair it, you have no problem. If the engine has suffered oil starvation you may just be able to keep it going for a while; if this is ok with you. If the remainder of the truck is in good shape and you can afford it, and are looking forward to many good years, you can go ahead and replace the motor.
Old Feb 10, 2008 | 07:56 PM
pdqford's Avatar
pdqford
I would suggest that if the engine did not have regular oil changes and its sludged up, then that abrasive oil circulating through the bearings, piston/rings, and valve train has caused all the clearences to wear to excess. Cleaning the engine internals isn't going to fix the problem.
For this particular porblem, I'd want to get a hold of a mechanical gauge and put it on there and see just what the oil pressure actually is. If oil pressure is insufficient, the motor is probably already toast.
Old Feb 10, 2008 | 09:14 PM
2mortime's Avatar
2mortime
Question Low Oil Pressure
What should the oil pressure read?
Old Feb 10, 2008 | 09:47 PM
pdqford's Avatar
pdqford
Oil Pressure (Hot @ 1500 RPMs) = 138-310 kPa (20-45 psi)
Old Feb 11, 2008 | 04:42 AM
2mortime's Avatar
2mortime
Low Oil Pressure
Thank you all for the great information given!!!!!
Old Feb 12, 2008 | 11:47 AM
MPBTim's Avatar
MPBTim
Hey there.
I have a 2000 expy 4x4.....the sending unit was a pisser to change. But the cycling you describe is exactly what it was. The sending unit.
Once I had that replaced. no issues.
Good luck.
06FUN
Oct 29, 2016 07:53 AM
AZRogala
Computer Chips & Tuners
17
Dec 11, 2015 04:30 PM
campersieg
Oct 28, 2009 09:46 AM
michaelgr
Bronco II
Jan 10, 2008 02:53 PM
Technocrsr
Jun 6, 2007 08:27 PM
