I hate this Auto trans !
Old Feb 10, 2008 | 12:45 AM
slisty's Avatar
slisty
I have a 05 F-250 6.0L, 4X4, auto trans. About 2 weeks ago I found a big red spot in the drive. Well the trans cooler line was leaking. The stealership charged me 130 bucks to fix the fitting at the trans tailshaft.
Well guess what its leaking again and the trans is shifting like crap now too. Its full of fluid but it feels like it is surging for a gear and in the morning after a 10 min warm up it takes about 20 sec to go in gear and when it does go in it slams in gear and jerks hard. I changed the trans filter 5k ago fluid has always been sp.
I have 2 questions here
1: what is the factory warrenty on the trans ( I thought it was 60k I only have 40k on it )
2: What could be making this happen ? ( the surging )
Old Feb 10, 2008 | 12:48 AM
REELNAUTI4U's Avatar
REELNAUTI4U
Remove your mods and enjoy a truck, motor , and transmission that will have no issues ?
Old Feb 10, 2008 | 12:55 AM
KRDiesel's Avatar
KRDiesel
I do not think his mods are causing it to leak.
If you have a leak in the system you may be pulling air into the system causing foaming. That will cause the problems you are describing.
The trans in under a 3X36 warrenty if i remember corectaly.
Old Feb 10, 2008 | 12:58 AM
Mulepick's Avatar
Mulepick
So the transmission isn't part of the "powertrain"? As in 100k powertrain warranty?
slisty's Avatar
slisty
That makes more sence ! Thank you and I think your right on the warrenty too. 60k was wishful hoping I guess lol
Old Feb 10, 2008 | 01:04 AM
KRDiesel's Avatar
KRDiesel
If it was my truck I would crawl under it tomorow and snug up the fittings. Start it with the wheels properly chaked and have someone pull it through the gears to see if that stoped the leak.
Warning. if you are married and have good insurance being under the truck with it running and in gear is a BAD idea!!
BobsF350's Avatar
BobsF350
NOPE 3 years 36,000 miles
Old Feb 10, 2008 | 01:11 AM
KRDiesel's Avatar
KRDiesel
It is a 100k Diesel warranty, not a 100K powertrain.
Old Feb 10, 2008 | 01:37 AM
slisty's Avatar
slisty
She wouldn't do that to me as she would have to do the yard work ! She has already replaced everything else with toys and told me if one of them could do yard work she wouldn't need me Oh damn maybe she got a new one then can !
Old Feb 10, 2008 | 01:54 AM
rollerstud98's Avatar
rollerstud98
I'm going to put spome msnow mants pn any go find my trcuk, i lov emy auto trans na it s draivesa awesoms!!!!!!
Old Feb 10, 2008 | 02:06 AM
denman81's Avatar
denman81
huh?? rollerstud your cut off!!! no more beer toinight
Old Feb 10, 2008 | 05:21 AM
m350's Avatar
m350
What was that rollerstud ?? I'll drink to that,, lol,,good one denman
Old Feb 10, 2008 | 06:26 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
I think I read on here mid- 06 the tranny is warrantied up to 60k, before that just 3yr/ 36k
Old Feb 10, 2008 | 07:13 AM
bismic's Avatar
bismic
You are correct. My truck is a mid 06 and falls under a 60k warranty for the transmission.
Old Feb 10, 2008 | 09:38 AM
KRDiesel's Avatar
KRDiesel
I have a 03 so I only had a 3X36. I think somewhere on ford.com you can lookup what your warranty should be.
