Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Not impressed
Old Feb 10, 2008 | 10:33 PM
Fomoko1's Avatar
Fomoko1
Ryan too, his truck didn`t start the other day.
Old Feb 10, 2008 | 10:46 PM
Snowking's Avatar
Snowking
A 700 dollar tune up? Pthhh Not very fridgin likely for mine.
Old Feb 10, 2008 | 10:56 PM
Fomoko1's Avatar
Fomoko1
Plugs/wires don`t cost very much when you install them yourself, even a quick tuneup will save you gas $$$.
In the long it`ll pay by saving wasted fuel and it`ll at least have a chance of starting in -30....
Suit yourself, you can pay for afew tuneup parts, some injector cleaner or spend alot more at the pumps......
Old Feb 11, 2008 | 05:45 AM
96sherm's Avatar
96sherm
i like your thinking Fom. preventative maintenance!! i've always went that route, and touch wood, i've been fortunate.
Old Feb 11, 2008 | 08:16 AM
51dueller's Avatar
51dueller
A tune up on these trucks are fairly simple, all you need is a $10 DVOM and some specs. There are only a few sensors and most are simple to test or clean:
Throttle body - clean with intake cleaner
Intake Air Bypass - remove and clean with intake cleaner
Intake Air Temp - Normally at high kms it's just best to get a new one instead of trying to clean
Intake Coolant Temp - normally doesn't cause a problem and just a simple resistance test
Throttle Position Sensor - adjust till it's just under 1 volt
Manifold Pressure Sensor - Can't do much other than make sure the vacuum hose has a good connection.
Oxygen Sensor - Only can be tested on a portable lab scope and should be replaced every 150 000 kms. I think you only have one anyways.
Then it's pretty much a standard tune up, rotor, cap, wires, plugs and reset timing. I'd recommend a Mitivac fuel flush, it costs $100 but it is well worth it as it cleans the entire intake fuel system out. It also works on carbed vehicles too.
The trucks kind of got the short stick when it came to the EFI setup. The cars got all the improvements while they still used the same setup from 1986-94.
Cost:
DVOM - $10
Intake cleaner - $5
Spark Plugs - $25
Wires - $40
Rotor and cap - $20
Intake Air Temp - $30
O2 Sensor - $80
Mitivac Flush - $100
Total - $310
Old Feb 11, 2008 | 09:16 AM
skidooman's Avatar
skidooman
My wife's old mustang wouldn't start the first winter we were here in Regina, I checked fuel pressure, changed rotor and cap, and eventually when I put new plugs in it she fired right up!!
Old Feb 11, 2008 | 05:03 PM
Snowking's Avatar
Snowking
Maintence is defiantly up there on the list but in a year from now the 351 will be sittin in Hub City steel, probably with 70-80% of the 93 .
Old Feb 11, 2008 | 05:11 PM
Fomoko1's Avatar
Fomoko1
That`s not real encouraging news for the 93.....
Old Feb 11, 2008 | 05:54 PM
96sherm's Avatar
96sherm
why don't you sell it first Ryan... or offer it for sale. don't just crush it, for crying out loud!!
Old Feb 11, 2008 | 05:58 PM
Fomoko1's Avatar
Fomoko1
By selling the 93 for scrap you might get $100/150 on a good day, that`s not even a set of used tires/rusty steel rims.....
Old Feb 11, 2008 | 06:33 PM
Snowking's Avatar
Snowking
I'm not crushing it outright of course, just parts are finding new homes. The front clip (maybe) will go into the 69 with the rear ends gear swap. The tranny/transfer case/ drivelines will go into the 69. The seats are headed to the 52. Actually Preppy wants the 351W.
I will also be parting out a 1987-90 Ford F150 I didn't buy yet for this project so I will have many parts if people are interested.
First come first serve.
Old Feb 11, 2008 | 06:43 PM
preppypyro's Avatar
preppypyro
You let me know when you get the parts vehicle Ryan. I may not be able to come get the parts first, but I will definatly send you a cheque and pay first!
Hell Ill even give ya a cheque that isnt bouncy haha.
Old Feb 11, 2008 | 07:00 PM
  #28
Snowking's Avatar
Snowking
of course this project is still in planning/preperation but should be top priority. Be nice to have a cool winter vehichle and since the 49/52/Internationals are great and priceless summer cruisers the 1969 is expendable enough to use as a winter work truck, but of course treated right.
I really like the 69 for some reason, but why would I ever drive a 1969 around when I got a 1949, right?
Old Feb 11, 2008 | 07:08 PM
  #29
preppypyro's Avatar
preppypyro
I couldnt agree with you more, that 49 is sweet. Maybe you should get another one, and put the 49 body on a 4x4 frame, you could put a flathead in there, that would be a sweet winter vehicle!
Old Feb 11, 2008 | 07:09 PM
  #30
96sherm's Avatar
96sherm
that would be a sweet winter driver.
