Sponsored by: Auxito
starter wire bolt
Old Feb 9, 2008 | 07:26 PM
JP_McCann's Avatar
JP_McCann
starter wire bolt
how do I remove the nut that holds the starter ground wire in place. When I try to loosen the nut the entire bolt moves. Any suggestions or tips to getting this off?
Thanks
JP
Old Feb 9, 2008 | 08:45 PM
superdutymj's Avatar
superdutymj
the ground post on the starter?
Old Feb 9, 2008 | 09:07 PM
JP_McCann's Avatar
JP_McCann
I need to replace the wire. So i really only need to take off the nut that holds the wire on to the starter ground post. However when i try to remove the nut the entire post spins. all I need to remove is the ground wire to replace it.
Old Feb 9, 2008 | 09:10 PM
superdutymj
just unthread the post all the way, you'll just have to replace the wire and then put it back in.
Old Feb 9, 2008 | 11:10 PM
JP_McCann's Avatar
JP_McCann
the only problem with that is that i can't take the post althey way out because the wire will try to spin arounf the post, but there isn't enough wire.
JP
Old Feb 10, 2008 | 11:38 AM
superdutymj
so cut the wire, you're replacing it anyway...
Old Feb 11, 2008 | 11:13 AM
JP_McCann's Avatar
JP_McCann
Any one have any other sugestions? not sure i want to cut the wires right yet. I might try to get them off in one piece if i can
Old Feb 14, 2008 | 01:46 AM
superdutymj
why can't you hold the eyelet of the wire with one hand while you turn the post with the other?
Old Feb 14, 2008 | 06:37 PM
bosshoss's Avatar
bosshoss
I had one to day that did that. If you have a air compresser, and a 3/8 air impact gun it will brake the nut loose after you tighten it back up. If not use a 13 or 14mm wrench i think that has been ground down to fit between the nut and cable. Good luck.
Dave P
openexcess
Jun 16, 2011 09:41 PM
JP_McCann
1997 - 2003 F150
Jun 16, 2010 12:20 AM
JP_McCann
1997 - 2003 F150
Oct 29, 2009 07:48 AM
JP_McCann
1997 - 2003 F150
Jul 7, 2008 08:13 AM
blksiryder
Bio-diesel, Propane & Alternative Diesel Engine Fuels
May 31, 2007 06:45 PM
