Truck will not start
Old Feb 10, 2008 | 12:17 PM
screwy's Avatar
screwy
Another thing you could check is the starter has a dedicated wire running from the positive battery terminal, maybe that isn’t making good contact.
Old Feb 10, 2008 | 12:20 PM
zfisher1985's Avatar
zfisher1985
truck woln't start
Ya if you know how to bypass the secrilock system may that would help, As for the relay, i thought they would reset themselves if they were tripped.
Old Feb 10, 2008 | 12:25 PM
screwy's Avatar
screwy
Relay, not circuit breaker. Anyways I strongly suggest you check you battery terminal to make sure the starter wire is in good shape. I’ll send you a PM on how to bypass the PATS, no need to let the world know. I don’t think that’s your problem, but it will also rule out some other things.
Old Feb 10, 2008 | 05:50 PM
J B M's Avatar
J B M
I have the same problem! I was replacing the factory head unit with an aftermarket one, and now this truck won't start either. It's an 04 f-150. Everything else works fine...all the dash lights come on, the horn, hazards head lights everything...but the truck won't start!
We spent a total of 11 hours so far checking every fuse and relay in the truck and they are all good. I have no idea what else it could be. We traced the yellow / blue trace wire all the way to the fuse box and there aren't any fusable links on it that we found...we even disconnected the wire that goes to the starter and jumped it with a 12V source and it kicks over but will not start.
Does anyone know what this could be...? Is it something the dealer can reset for me? I already put the factory radio back in.
Thanks,
John
Old Feb 10, 2008 | 06:54 PM
screwy's Avatar
screwy
Is the little red light up by the windshield blinking really fast when you try to start it?
Old Feb 10, 2008 | 07:36 PM
J B M's Avatar
J B M
I'll double check but I think it stays steady red while trying to start it. I just don't want to have to tow it up to the ford dealer because I know they'll probably charge me alot to bypass or erase any code it may be throwing.
Old Feb 11, 2008 | 02:23 PM
J B M's Avatar
J B M
Yep...steady red light, and the dealer said there is no communication with the ECM and is trying to figure out what is wrong with it.
I'm at a loss right now...
Old Feb 11, 2008 | 06:56 PM
zfisher1985
took mine to the dealer.....5 hours in -12 temp...I had enough...turns out whoever had the truck before me had an additional security system put on it and apparently it doesn't like it when you remove the neg side of the battery...it locked out the ignition and wouldn't let it start...back mobile now thanks for all the suggestions!!!
Old Feb 11, 2008 | 07:37 PM
J B M's Avatar
J B M
Holy cow...that's exactly what they told me today! That the previous owner either had or tried to put in a security system or remote start system and that's what caused it...!! They then told me that I need to replace the wire harness under the hood because it's not communicating with the ecm, and I'm looking at about $2K total.
Old Feb 11, 2008 | 08:14 PM
black04lariat's Avatar
black04lariat
So if you have an alarm installed and then your battery needs to be replaced you are screwed? That seems odd.
Old Feb 11, 2008 | 08:45 PM
zfisher1985
ya that what i thought.....but the dealership bypassed it all for me they said good thing i didn't go messing around with it cause it could have voided my current warranty... they told me they justed bypassed the ignition wiring that caused it to lock out...running like a champ now
pbjosh
Jan 25, 2015 06:26 PM
kevin206
Oct 27, 2014 09:32 PM
67F250RET
Feb 1, 2013 08:51 AM
hivolt5.0
Jun 22, 2011 08:17 PM
SHEFFBOY2
Electrical Systems/Wiring
May 16, 2009 01:02 PM
