Will Not Start Now
Old Feb 9, 2008 | 06:34 PM
DBANDGB's Avatar
DBANDGB
Will Not Start Now
My Son Had To Unhook Fuel Line At The Filter . He Had To Pump Out Gas & Diesel From Tank. He Had To Turn On The Key To Get The Pump To Work & At The Same Time The Glow Plugs Go On. Then The Pump Stops. Turn On The Key Again To Pump Out Gas. Had To Do This Many Times To Get Out About 7 Gals. Filled With New Diesel & Qt. Of Oil, ( Weather Was Warm ) Started & It Drove Fine. Could He Have Damaged The Glow Plugs Doing Above. Wont Start In The Cold.
Old Feb 9, 2008 | 06:59 PM
bismic's Avatar
bismic
There are others here that have experienced mixing gas w/ diesel - hopefully they will see this and comment. I do not think it helped your cause adding a quart of oil to the diesel (if I read your post correctly). A lot of problems can develop when additives that can cause soot in the exhaust (circulated back through w/ the EGR) are used.
I do know that some are using ASHLESS 2 cycle oil as a fuel additive, and they swear by it. Just remember, the 6.0L engines are more demanding of good fuel. The ratio that some use for the 2 cycle oil (as I recall ) is 128:1 which would be 1 quart for 32 gallons (apprx). Anything more than that I would think is NOT advisable. Personally, I feel there are better additives than 2 cycle oil (like biodiesel), but to each his own.
I really doubt that he would have ruined the glowpugs.
Old Feb 9, 2008 | 08:12 PM
F350-6's Avatar
F350-6
I don't know if it damaged the glow plugs, but if it ever happens again, you can disconnect the fuel line and wrap a rag around a blowgun from an air compressor (20 psi or so) and pump the fuel out of the tank that way.
Old Feb 9, 2008 | 08:33 PM
bismic's Avatar
bismic
Are you saying it starts fine in warm weather?
Old Feb 9, 2008 | 09:13 PM
brickie's Avatar
brickie
Check the batterys.
Old Feb 10, 2008 | 12:59 PM
DBANDGB's Avatar
DBANDGB
I Made A Mistake
My Question Should Have Been In The 7.3 Section. Batteries Good. It Turns Over Fast. The Weather There Has Not Warmed Up. To Be Able To Start Except With Some Starting Fluid ( Which Is Not Good ) The One Time It Started Was After He Pumped Out All The Garbage, Filled & Installed New Fuel Filter & New Fuel In Tank & That Day It Was About 60 Degrees.
Old Feb 10, 2008 | 03:51 PM
Kusto's Avatar
Kusto
I would not advise this procedure at all as any spark in this now oxygen rich environment will result in an explosion. I would rather suggest that you put a vacuum on the discharge hose (small electric fuel pump) to draw the fuel out rather than introducing additional oxygen to the mix.
