Extreme heat paint?
Old Feb 9, 2008 | 06:00 AM
officer131's Avatar
officer131
Question Extreme heat paint?
I would like to paint my intercooler pipes the same color as my truck. It old man beige and tan however its still a beast on the road being an excursion. What is a good brand name paint that would coapply well to the pipes and actually with stand the heat from the engine.
AL
Old Feb 9, 2008 | 07:21 AM
MBDiagMan's Avatar
MBDiagMan
I don't know the exact temperature that you can expect on Intercooler components, but I expect it to be much lower than exhaust parts. Exhaust parts would be hopeless to paint with color, but the Intercooler may very well take lacquer with good results.
Good luck,
Old Feb 9, 2008 | 02:36 PM
blue68f100's Avatar
blue68f100
If the parts are removable you can have it cermec coated, similar to powder coat.
Old Feb 10, 2008 | 02:08 AM
Sycostang67's Avatar
Sycostang67
I used 500* paint on some exhaust manifolds once and it all burnt off while breaking in the cam. My brother used 1500* paint on his manifolds but we wont be running that motor for a few more weeks. I did use 1200* paint on some headers once, it head up real well except for the fact I didn't clean them as well as I should have and the rust is causing the paint to flake off. I'm not sure what temp your intercooler pipes will reach, but I thought I could give you some baselines regarding temp. The 2 paints I used were the duplicolor with ceramic. I believe my brother used VHT.
Old Feb 10, 2008 | 07:36 AM
officer131's Avatar
officer131
thanks for the input guys. I might just buy a can and try it. If it doesn't work then not that much invested in it.
Al
Old Feb 13, 2008 | 07:27 PM
anotherfordguy's Avatar
anotherfordguy
The innercooler pipes can be painted with 500* paint but would use 1200* ceramic since they are close to the turbo outlet. Mine have been painted for a year and still look good.
bubba.whit6.4
6.4L Power Stroke Diesel
May 24, 2016 09:28 PM
Not Rocket Science
New Member Introductions
Mar 1, 2016 12:24 PM
GaryKip
Jan 19, 2016 05:19 AM
kengarchow
Jan 5, 2016 01:49 PM
abe
Dec 23, 2009 10:41 AM
