engine component paint types
Old Jan 18, 2016 | 05:41 AM
GaryKip's Avatar
GaryKip
I have a stock type of engine breather (the one that the hot air snorkel is connected with a flex pipe to the exhaust manifold) and after I clean it up I want to repaint it (blue, of course). The directions on the rust-tol-eum can says not for areas where it gets 200 deg or more. Do you guys think I need to use the "High Heat" paint? Or will the regular enamel work? I"m not sure if the breather would get that hot on a 360 with a 2V carb.
Old Jan 18, 2016 | 08:05 AM
HIO Silver's Avatar
HIO Silver
Use engine enamels... not run of the mill spray paints.
Old Jan 18, 2016 | 02:02 PM
yetiman38237's Avatar
yetiman38237
I know regular paint will bake off the heads pretty darn quick. I ended up redoing my heads with enamel and it still looks pretty good. If truck was a daily driver it would be toasted by now. Doubt that the air cleaner gets anywhere near that hot.
Old Jan 19, 2016 | 05:19 AM
GaryKip's Avatar
GaryKip
OK, thanks HIO. Engine enamel it will be. I'm going to build one of those rust removal tanks reallll soon!!!!! My hands are sore after sanding that breather today.
Scout Pilot
1961 - 1963 F100 Unibody
20
Nov 25, 2012 04:30 AM
LARIAT 85
18
Jul 22, 2011 04:59 PM
fish-albuq
Mar 28, 2009 09:00 AM
JoeBlow
Paint & Bodywork
Mar 17, 2005 11:46 PM
Ken2600
Oct 11, 2002 12:38 AM
