posi vs limited slip
Old Feb 8, 2008 | 10:10 AM
wesh's Avatar
wesh
posi vs limited slip. what the difference if any, and what is better for off roading?
Old Feb 8, 2008 | 10:23 AM
75F350's Avatar
75F350
Posi
(positive traction) is a GM term, and LS is a Ford term for exactly the same thing.
Clutch type differential used to apply resisatnce to the side gears in an attempt to distribute power (bias) to both axle shafts.
Old Feb 8, 2008 | 11:25 AM
85e150's Avatar
85e150
Positraction (GM) EquaLock (Ford) Sure-Grip (Chrysler) Borg Warner Spin Resistant (for Chrysler, called Sure-Grip) Dana Power-lok (for Chrysler, also called Sure-Grip) Twin-Grip (AMC in the old days)
There are others, most of these are the clutch type limited slip. One is cones, but they all are "limited slip" diffs relying on spring pressure and friction to keep the axles turning together under power, but allow differential action in turns.
Lockers use more mechanical locking methods like ratchets to lock the axles together, they are noisier and more harsh.
"Posi" became the term applied to all because:
--GM was the biggest and pushed it and there were more positractions out there.
--It's easy to say
--It is an almost perfect term as it is what it says--positive traction.
--It's a four-letter word.
87thhunter
50
Mar 1, 2016 11:56 AM
FSSF
Feb 26, 2016 11:54 AM
defiantoutlaw
Mar 20, 2014 06:57 PM
xxshine
Feb 5, 2012 07:15 PM
notmmrw1
Aug 10, 2007 10:42 AM
