heater selector won't select
Old Feb 7, 2008 | 05:05 PM
speedracer54729's Avatar
speedracer54729
heat only blows from vents nomatter where leaver is
Old Feb 7, 2008 | 05:53 PM
quicklook2's Avatar
quicklook2
the hose has a vacuum leak.
look under dash with a light and make sure it is connected and no splits.
look in engine compartment for the same thing.
Old Feb 7, 2008 | 08:05 PM
jr32560's Avatar
jr32560
ditto with quicklook2-vacuum leak, hose split or came loose
Old Feb 7, 2008 | 10:46 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
check vaccum lines under hood, one of mine broke and i got the same thing, but it was stuck on defrost. Fix line, selector works just fine now.
Old Feb 7, 2008 | 11:14 PM
88F-150pimp's Avatar
88F-150pimp
Is your plenum door cable actuated? If so, you'll have to replace the control cable and rerout it through the dash. My truck has a cable actuated plenum door, but I'm not sure about yours.
Old Feb 8, 2008 | 09:19 AM
quicklook2's Avatar
quicklook2
his is vacuum.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
