Sponsored by: Innova
Adding another sub
Old Feb 7, 2008 | 04:01 PM
86F150302's Avatar
86F150302
Adding another sub
Right now I have 1 Kicker CVR12 sub and 1 Kicker zx400.1 amp. I want another 12" sub and was wondering what I should do for an amp. Should I get another Kicker zx400.1 and hook the 2 together?
How do you power the 2nd amp? Will I have to do everything I did with the first amp to the second?(power wire, ground,ect)
Or should I sell the current amp and buy one to power both subs? If so which amp? I will need 400rms to each sub.
Old Feb 7, 2008 | 08:03 PM
Prestige Wiring OKC's Avatar
Prestige Wiring OKC
You may want another amp to drive that other sub, I would get a larger amp to run both subs off of, thats the easiest way if not you'll need a distribution block for the power and ground. Dont run 2 amp kits. If you run 2 subs off 1 amp wire them in series.
Old Feb 7, 2008 | 08:36 PM
86F150302's Avatar
86F150302
ok guess Ill sell my current amp and get 1 amp to power both subs
Old Feb 7, 2008 | 09:34 PM
Prestige Wiring OKC
Hope it turns out well for you.
Old Feb 7, 2008 | 09:50 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
If you run both subs off of one amp. You know your getting equal power to both subs. But if you have 2 amps pushing two subs, the boxes will have to be seperate other wise you could damage you subs.
2002exPSD
Oct 8, 2011 09:40 AM
deisele75
2004 - 2008 F150
19
Sep 2, 2007 09:48 PM
'78 Custom
Feb 25, 2006 08:17 PM
panteramatt
Jan 15, 2004 12:03 AM
Munkey
Nov 29, 2001 04:23 PM
