General Automotive Discussion
Mass Air conversion
Old Feb 7, 2008 | 12:59 PM
bert74's Avatar
bert74
Mass Air conversion
Just converted truck over to a mass air conversion. Check engine light came on after completion. Code 67-Neutral Drive Switch Circuit Open/ A/C on. What should I do for that.
Old Feb 7, 2008 | 02:03 PM
Bart99GT's Avatar
Bart99GT
Is the truck an automatic? Then you probably need to add/connect the neutral drive switch.
But in reality, you can ignore the code. It won't harm anything. Most vehicles don't even trigger a CEL for something like that. That input is only used to determine when to raise the idle 100 rpm or so when the transmission is in gear or the A/C is on.
Alternatively, you could just jumper the connection so that it detects continuity in the circuit when expected.
Old Feb 7, 2008 | 02:19 PM
bert74's Avatar
bert74
It is a Standard no air conditioning
Old Feb 7, 2008 | 04:20 PM
mrshorty's Avatar
mrshorty
I assume this is pre '95/EEC-IV/OBD-1. 95% of the time, a KOEO 67 indicates that you performed the KOEO test with the transmission in gear. The computer expects to see the transmission in N during the test. Repeat the KOEO test, being sure the transmission is in N. If you still get a KOEO 67, then go over the neutral position switch circuit to make sure there are no problems.
In saying that, that applies to Ranger based vehicles that I'm familiar with. I don't know what applications use a KOEO 67 to refer to the AC system, but I expect it's a similar scenario. We'd have to know what you're working on.
Old Feb 7, 2008 | 09:41 PM
Bart99GT's Avatar
Bart99GT
Just ignore it. On a pre-OBD-2 computer, the CEL usually doesn't tell you much that you didn't already know. Generally the CEL on EEC-IV will accompany a rough running/low power/poor fuel economy engine. So pull the bulb out of the dash and be done with it.
Old Feb 8, 2008 | 12:44 PM
rebocardo's Avatar
rebocardo
What truck, what engine, what year?
As an example, on a 2.3L it can make a big difference if the computer thinks your A/C is on.
ccecilm2
2004 - 2008 F150
20
Feb 18, 2009 08:13 PM
thenewbreed
Texas Chapter
Apr 11, 2008 09:31 PM
Bowie
6.4L Power Stroke Diesel
Feb 27, 2008 07:16 PM
Imdok
Oct 11, 2007 01:11 PM
econolinedriver
1997 - 2003 F150
Feb 17, 2007 07:58 AM
