429 Fuel Pump
Old Mar 14, 2001 | 10:40 AM
dmo1's Avatar
dmo1
429 Fuel Pump
Does anyone have a recommendation for a performance mechanical fuel pump for a 71 429? Tried the Holly 12-460-11 and it won't work because of the difference in the shape of the actuator arm between the Holley and stock.
Dennis
Old Mar 14, 2001 | 12:14 PM
TBirdGuy's Avatar
TBirdGuy
429 Fuel Pump
Why are you curious to know the performance of a stock pump? I think they pump like 4- 5 psi, I'm not sure on the gallons per minute. Do you have a hi-po motor that requires alot higher pressure or more fuel? If it doesn't, a stock pump should be fine.
TBirdGuy
"Stuck with a m*par, Settle for a ch*vy, Happy with a Ford!!!!"
Old Mar 14, 2001 | 12:30 PM
dmo1's Avatar
dmo1
429 Fuel Pump
T Bird Guy
Yeah the 429 is pumped up with a 850 holley double pumper on it. That's why I am looking for a higher volume pump.
Thanks
Dennis
Old Mar 14, 2001 | 02:01 PM
TBirdGuy's Avatar
TBirdGuy
429 Fuel Pump
Oh, ok. If I were you, I'd call the Holley tech lines and see what the said. It doesn't make sense that their Fuel pump wouldn't work. Worst comes to worst, put a block off plate where the mechanical pump is and just run an in-line electric pump.
TBirdGuy
Old Mar 14, 2001 | 03:33 PM
dmo1's Avatar
dmo1
429 Fuel Pump
TBirdGuy
Thanks. In communication with them now. They are talking with their designer and I think they want to see my old pump.
Thanks for the help
Dennis
Old Mar 27, 2001 | 09:18 AM
dmo1's Avatar
dmo1
429 Fuel Pump
Update and thanks to all who helped. Went with a Edlebrock pump. Had to use their conversion kit to switch from a side feed to a bottom feed, but the arm on their fuel pump is higher and allows more movement.
Holley has been great though. Called me at home and are really interested in solving the problem. I am sending them both their pump and my old stock pump to compare. Can't say enough about their service.
Dennis
55F100(429)
Old Mar 27, 2001 | 03:02 PM
cobrajet's Avatar
cobrajet
429 Fuel Pump
CARTER also makes a bolt up after market pump, using one right now on my big block 7 p.s.i. all the time. just bolt it up with no problem, and just redid my fuel line. very nice pump. ....
Old Mar 27, 2001 | 03:08 PM
dmo1's Avatar
dmo1
429 Fuel Pump
Cobrajet;
Thanks for the reply. What's the number of that pump? Side, bottom or front feed?
Dennis
55f100
Old Mar 28, 2001 | 04:40 AM
cobrajet's Avatar
cobrajet
429 Fuel Pump
what's up, the pump is a bottom feed. and if your standing in front of your truck looking at the front of the motor, the fuel lines come in on the drivers side. the number is ( M60882 ) for the carter pump.i bought it from either JEGS or SUMMIT i can't remember. about the only thing you'll have to do is probally run over to your hardware store and buy a fitting to adapt to your current fuel line or new one. i think the base of the pump is rotatable, turn it the way you want. it bolted right up to my set-up and works great. i use the older style power steering pump on my 77 f-150, looks like a small round pump with the dip stick in the back. take it easy. C.J. later....
Old Mar 29, 2001 | 12:01 PM
Mudman's Avatar
Mudman
429 Fuel Pump
LEO56F100
Apr 7, 2015 10:11 PM
Michael Levy
15
Dec 17, 2014 05:12 PM
7mpg302
Dec 3, 2008 06:17 PM
JiveBoogle
Alberta Chapter
Sep 15, 2002 09:36 PM
