U Joint question
Old Feb 6, 2008 | 07:03 PM
kappysworld's Avatar
kappysworld
U Joint question
Ok, I have 93k miles on a 2000 X V10 I tow over 13K lb once a month. I have started hearing clank from the Drive shaft and it seems like its time to replace the U joints anyone have any suggestions othere than OEM...
Old Feb 6, 2008 | 07:23 PM
i eat hybrids's Avatar
i eat hybrids
did u try and go under ur truck and move the drive shaft with ur hand?
Old Feb 6, 2008 | 07:40 PM
kappysworld
Yup, there is some movement. Its a cheap replacement cost so not too worried about it,. But if there is better than OEM and its not too $$$ I am all for it..
Old Feb 6, 2008 | 07:41 PM
i eat hybrids
I dont kno bout u joints (nv had to replace) but, if kno one chimes in, i cant she y u wouldnt go with OEM, they got u 90k. Also how are the fronts?
Old Feb 6, 2008 | 08:41 PM
Brians97F250Crew's Avatar
Brians97F250Crew
one thing to remember is if you change type of joints from factory to something else. Like ones with grease fittings in the ends, caps, or in the cross. It'll change the balance of the shaft. Even with factory replacements you might have a minor balance issue. Stock ones are always the safest bet.
Old Feb 6, 2008 | 10:24 PM
Move over I'm coming's Avatar
Call around and get Spicer u-joints. They are the best IMHO.
Usually a drivetrain supply or NAPA carry them or can get quickly since yours are just starting to make noise.
Replace both on the shafts and remember to scribe a line between any slip joints to maintain factory balance in the shaft assys.
Put it togeather the same as it came apart you will be ok.
Rich.
Old Feb 6, 2008 | 10:28 PM
i eat hybrids
kappy, u gonna do his ur self?
Old Feb 6, 2008 | 11:33 PM
kappysworld
No sir I am gonna have a shop do it. I would normally do it myself but I have no time before this weeks trip. Plam Springs for kids cheerleading
Old Feb 7, 2008 | 12:04 AM
i eat hybrids
Ok, let us kno how it goes.
Old Feb 7, 2008 | 08:14 AM
Downriver Thunder's Avatar
Downriver Thunder
The first time I had my rears done I ended up having to have a new driveshaft installed. The shop tried and tried to balance it but gave up.
redsuperduty
Feb 6, 2026 05:07 PM
hairyboxnoogle
Jul 1, 2014 07:01 PM
trucktech
Mar 6, 2011 12:20 PM
rlh68050
Apr 21, 2010 08:57 PM
89LX306
Sep 18, 2009 08:54 PM
