ZF6 fluid (Mobil1?)
Old Feb 6, 2008 | 05:17 PM
carlsson's Avatar
carlsson
ZF6 fluid (Mobil1?)
I have seen in posts here several recommendations for using Mobil1 Synthetic ATF for the 6 speed. I went shopping for it, and all the local stores- Walmart, Pep Boys, Autozone only had Mobil1 synthetic MerconV. The NAPA and Advance also had no synthetic Mercon. The 2000 owners manual says to use a conventional Mercon (not MerconV) and specifically states to not use MerconV or Mercon/MerconV fluids in the automatics that specify Mercon. It states to use synthetic mercon for the ZF5. The dealer wants over $22 a quart for the synthetic Mercon for the ZF5. A local manual trans. rebuilder advised that I use any synthetic ATF whether Mercon or not. I wanted to make sure before I change to MerconV. Any advice?
Old Feb 6, 2008 | 08:19 PM
F350-6's Avatar
F350-6
I've just used the regular stuff every 50k or so with no issues. It still looks clean every change. I'll be due for another change in a couple of months so I'll pass on the $22/qt.
Old Feb 6, 2008 | 09:21 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
He's right. Any good synthetic ATF will work better than the stock stuff. I use Royal Purple because NAPA stocks it.
kawika
49
Jun 23, 2021 11:47 PM
cavitation
May 21, 2015 06:52 PM
pony
Mar 27, 2014 10:07 PM
Rich in CO
23
Jun 17, 2006 02:37 PM
venom_99
Feb 9, 2004 11:58 AM
