teeth gone on flywheel
Old Feb 6, 2008 | 03:56 PM
2 stroke man's Avatar
2 stroke man
the starter rebuilder put my starter back on, and thought the new bendix was bad cause of how she grinded. he pulled it, tested it, and says their is two teeth gone on the flywheel cause he pulled the dust cover and turned flywheel. he said he wouldnt worry bout it. ideas?
Old Feb 6, 2008 | 03:58 PM
bigbadwolfe's Avatar
bigbadwolfe
auto or 5speed
Old Feb 6, 2008 | 07:47 PM
2 stroke man
auto. that means no roll start-i know LOL
Old Feb 6, 2008 | 07:54 PM
tjbeggs's Avatar
tjbeggs
two will turn into 3 and 3 will turn into 4 plus they will take out the starter drive. Might be able to run it for a while like that but it won't take too many times of the engine stopping on that spot to make it worse.
How did it get like that?
Old Feb 6, 2008 | 07:56 PM
Robbgt's Avatar
Robbgt
Happened when I got my truck. Had a shop replace it (called Flex-Plate on auto trans) I didn't have the time or tools. Starter would grind. If yours is bad enough that it grinds alot I would replace it
-Robb
Old Feb 6, 2008 | 07:57 PM
bigbadwolfe
thank you robbgt flex plate
Old Feb 6, 2008 | 07:59 PM
2 stroke man
mine only ground the once, at the shop. never done it on me. they said someone had turned key with her running. how do you not hear a patterin powerstroke straight piped running?
Old Feb 6, 2008 | 08:15 PM
tjbeggs's Avatar
tjbeggs
How long have you owned the truck? maybe it has been like that for a long time. I would just give it a shot and see what happens. It will let you know when its getting worse!
Old Feb 6, 2008 | 08:17 PM
2 stroke man
i had it a year last september and never a prob. my guess is i had someone move it in a parking lot or barn lot and they hit the key not paying attention
Old Feb 6, 2008 | 08:44 PM
fordman837000's Avatar
fordman837000
the flex plate is cheep enough its like 100 - 150 bucks but you gotta pull the tranny back unbolt it from the tc and then the crank then remount it. I did mine while I had the tranny out I had no choice mine cracked in a perfect circle around the crank bolts. I guess the banging tranny finally killed it. well I since replaced both and no problems yet knock of wood!! Autozone can order them I think I payed 90.00 for mine.
Old Feb 6, 2008 | 08:51 PM
fordman837000
[QUOTE=fordman837000]the flex plate is cheep enough its like 100 - 150 bucks / I payed 90.00 for mine. I' m such a tard some times! Anyway its around 100 bucks SORRY FELL OFF MY SHORT BUS! LOL
DrZoom
16
Apr 6, 2016 11:42 AM
88F700
Large Truck
May 11, 2015 03:48 PM
padd54
Jul 18, 2004 09:45 AM
stanky
Engine Swaps
Jun 13, 2004 07:28 AM
j.foster62
Jan 6, 2004 09:06 PM
