460 Potential Vs. 400m?
Andrew
78 ford bronco 4x4 351m (soon to be 460)
>Glad you find this so humorous,
>that's what we're here for...to
>entertain you.
you m-block fellows ARE entertaining!!!
>You can't compare a high comp
>motor to a low comp
>motor. It's apples to oranges
>so quit trying...
i thought this thread said 460 vs 400m!! not low comp 460 vs a low comp 400m. it seems you add or twist things around to make yourself feel better about your small block.
its a small block vs a big block, thats your apples and oranges
bill beyer, in your first post in this thread, you make reference to motor in a magazine, what you fail to mention is how much it would cost to drag 380+hp and 450ish #tq out of a small block. i'm betting it would be quit expensive.
EVERY STOCK 429/460 (pre 72) made that kind of power, and for the post 72 460's, it would be alot cheaper to build to obtain those numbers. and thats the name of the game, to get the most bang for the buck.
>blah...blah...blah...heard it all before. Spoken like
>someone who's never built a
>400...
bill beyer and 400hp794x4 without being smart guys,
please explain to me the difference in building a 400 or a 460. is the crank mounted in the carb or something??? or do the pistons go in upside down?? does the tranny mount to the water pump?? or maybe the heads mount on the bottom of the block. no, i think it's built in the same fashion as a 460, so why do you keep refering to people who have never built a 400??
>What year motor? It makes a
>big difference in case you
>weren't aware. The 460 is
>always going to make "more
>power" if you're talking strictly
>hp, it's got 60 more
>cubes. It doesn't take a
>rocket scientist to figure that
>out. However assuming a comparable
>C.R. for both motors it's
>very possible that the 400
>will make more torque lower
>down than the 460 because
>of the significantly longer stroke.
i am aware of and
i would'nt exactly call a 4.00 stroke on the 400 significantly longer than the 3.85 stroke on the 460, but anyway, in 75 a factory fresh 400 made 155-160 hp @ 4000 rpm and 275-280 #tq at 2000 rpm. a factory fresh 460 made 220-225 hp @ 4400 rpm and 355-360 # tq at 2800 rpm, oh yea, comp ratio's, 8.0:1 on the 400 and 8.5:1 on the 460.
now in your own words, comparable cr's, where does the 400 possibly out-torque the 460, or are we still talking apples and oranges, because 8.0:1 - 8.5:1 are as close as we can get.
>a small block. i'm
>expensive.
Well if you'd taken the time to read the article you'd know it cost right at $2000, so you'd lose that bet...
> smart guys,
not much of a stretch...sorry couldn't resist.
>no, i
>so why do you keep
>never built a 400??
Seems to me someone in this thread said something about not having a clue if you didn't own a "ground pounding, pre-72 460".
Do those engines have something really special like hand cranks or what?
>at 2000 rpm. a
>hp @ 4400 rpm and
> 8.0:1 on the 400
>we can get.
A. .15 is a significantly longer stroke in the world of engine building. If you don't know that then you haven't built many engines.
B. If you're gonna compare #s then quit pullin' them out of your nether regions. In 1972 the 400 was rated at 172 net hp @ 4000 while the 460 was rated at 212 @ 4400. That means that the 400 had .43 hp/CID while the 460 had .46 hp/CID. But the 460 had the 4V while the 400 still had the 2V. You wanna talk torque? Fine, 400: 298# @ 2200, 460: 342# @ 2800. Once again 2V vs. 4V and the C.R. was 8.4:1 for the 400 and 8.5:1 for the 460.
I'm not trying to say the 400 is a better motor, all I'm saying is that with a little massaging it will stay right up with a big block without paying the weight penalty or having to spend the $$$ for a swap.
>through and read all your
>posts in this thread... Not
>one of them are particullarly
>helpful, generally you just rag
>on what someone else said.
>Lighten up!
As opposed to this little gem which was your first post in this thread:
"Reliabilty? Ha! The 400 is a peice of trash. I have one in my bronco and I curse it everymorning. (I am going to a 460) I hear about thier main bearings going out all the time. Mine has 140k on it and it is damn near junk. I dont even know if the motor is oribinal or not. When you have to build a 400 like crazy just to out do a stock 460 or 429 there is a problem. The 400 is SOOOOOOO dead in the low end its embarrasing. Actually its dead in general except that I put a cam in it a year ago and that gave me a bit of high end so now it is just dead down low and lamost dead up high."
Spare me the whining.
This is just off the top of my head so please dont jump on me if im wrong (but please let me know if im wrong or right).
>bet...
quit acting like your rich, 2000 is alot of money, especially to waste on a small block, when you can find an older 429/460 for 300-500 bucks, it will bolt right up to the original tranny, it already produces the power you spent 2000 to get. and best of all, you could do it probably for less than 1000.
>pre-72 460".
>what?
see, you still haven't answered my question. you, along with other people, keep refering to those of us who have never rebuilt a 400, again, i ask, whats so special about a 400????
>built many engines.
i guess .15 is to me like 2000 is to you.
without sounding like i'm bragging, i have 5 big blocks in my garage and 3 more in the trucks i drive. 3 fe's and 5 385 series. 4 which i have completely rebuilt, including a 521 cid ground pounder!!!!
>at 172 net hp @
>the 460 had the 4V
>for the 460.
it doesn't matter what year you use, the 400 still comes up short.
>a swap.
i don't know what your refering to with a little massaging, does that mean adding a new 4v, along with a new intake and cam? or does it mean advancing or retarding the timing???
if it means adding a new 4v, intake and cam, i can swap in a big block for what it would cost for those items.
>to waste on a small
> and best of all,
>for less than 1000.
Yeah I'm sure we can all run right out and find a 30+ year old motor in a junkyard that'll put out 385 hp and 470# of torque. Those babies are layin' all over the place in perfect shape just waiting to be picked up...please!
>about a 400????
If you don't know then you obviosuly haven't built one...
and your point is what...you're poor?
> 3 fe's and 5
>385 series. 4 which
If you've rebuilt these motors then you know it costs money or did you just pull different parts out of junkyard motors? In fact most decent rebuilds cost somewhere in the neighborhood of, oh say...$2000.
>up short.
It should, it's 60 cubes smaller than a 460 now isn't it?
>new intake and cam?
It means a complete rebuild with flat top pistons, a hotter cam, 4V carb & intake, timing changes & headers.
>can swap in a big
If that's the extent of your capabilities then that's what you should stick to. A man's got to know his limitations.
Look I didn't come here to trash the 385 series, the thread was about the potential of the 400 vs the 460. Obviously if you start with a bigger motor you're going to get bigger numbers and you can't easily make a 400 into a 460. There's a guy over on the M block forum who's pulling 667 hp and 564# of torque out of a stroked 400 with a stock block & Boss 302 heads so there definitely is potential there. Put whatever you want in your truck, as long as it has a blue oval on it you aren't going to go too far wrong.
>doesnt a 4v head just
>allow more power in the
>high end while taking away
>the low end? It seems
>that trucks would want more
>low end as it is
>not often that a 4x4
>is revved up to the
>high rpms in normal driving
>or towing. I would think
>if you put a 2v
>on a 460 instead of
>a 4v (you can do
>that cant you?) that that
>would bring the powerband down.
For the purposes of this discussion there's no functional difference between any heads on an M or 385 series engine based on carburetor size. Only 351Cs had heads designated for different carb sizes.
A 2V carb is going to run out of breath at a lower RPM than a 4V so the answer to your question is basically no. Unless you've changed to a cam which likes high RPMs then simply adding a 4V carb to an otherwise stock engine will not move your powerband up or down, only enhance it IOW you shouldn't lose anything on the lower end while you will definitely gain on the upper end with a 4V. OTOH putting a 2V carb on will simply shorten the powerband by cutting the top end off.
Theoretically it's possible to screw up your driveability by "over-carbing" but that's not so easy with engines of 400 CID and higher.
>out 385 hp and 470#
i don't know, i don't go to junk yards. last weekend i was out driving in the country, and saw 2 big lincoln continentals sitting out behind a farmers barn. i stopped and talked to the old fellow and bought both cars for 100 bucks. here's the good part, they were both 71's with the good 460's and c-6's.
so yes, they are out there, you just have to go out and find them.
like a broken record.
yes, but when i put 2000 into a big block, i get alot more out of it.
to me, that's more than a little massaging!!!!!
i guess i look at it differently, as an engines capabilities and limitations. not mine, despite what you say, it's easier to swap than rebuild, the old addage (if it ain't broke, don't muck with it) applys. of course, i guess your right, you have to tear down a 400 and rebuild it to get any kind of numbers out of it, compared to a big block, which already produces those numbers.
>of the 400 vs the
>a 400 into a 460.
>of torque out of a
>as it has a blue
>going to go too far
>wrong.
come on bill, be honest, how much do you think that guy spent on that motor? 5-10 grand? just think if you put that kind of money in a big block. that's 1000hp kind of money.
>to junk yards. last
>c-6's.
It's stil a 30 year old engine with an unknown history and I'd bet a month's pay it won't make the kind of numbers you keep claiming it will. Sure it's a great candidate for a rebuild but it's still just a starting point.
The point is all you've got is a bunch of heresay from people who claim the 400 is garbage. You've never taken the time to investigate why they say it or what could be done to fix it.
>into a big block, i
>it.
Well now how would you know that since all the engines you've rebuilt seem to be sitting in your garage instead of in your truck(s)? Besides if you didn't get more HP out of the extra CID on a 460 then you'd be pretty pathetic. I can still rebuild a 400 for the same amount of money and get very close to the HP and probably more torque.
Well there you go...
>it) applys.
Like I said, you've never built a 400 so don't talk about an engine's capabilities and limitations if you don't have a clue.
>of course,
>have to tear down a
Of course I'm right, but the point is that you love to talk about one or 2 specific years of 460s. What about the "smog years" 72-79 where Ford introduced the 460 to all of the same disadvantages that the 400 had to deal with from the beginning? You never like to talk about those do you? Those engines need just as much "massaging" as any 400...
>>of torque out of a
>>there
> 5-10 grand? just
>kind of money in a
>kind of money.
Sure he spent a chunk of money, he's a semi professional truck puller with class restrictions which prevented him from building a big block. What's your point? That was also his first shot at a 400 and he's in the process of building a bigger & better one right now. He'll probably get pretty close to 1000 hp out of it..
