2007 sport trac trans????
Old Feb 6, 2008 | 09:05 AM
02sd's Avatar
02sd
Question 2007 sport trac trans????
I have a 2007 sport trac 4.0 4x4, when I get on he brakes harder than a normal stop it seems to shift itself into neutral so when I go to take of again after the stop the engine will rev up and than the trans kicks into gear, very similar to a neutral drop, this only happens once in a while, it seems to be brought on by a hard brake only, Thanks
Old Feb 6, 2008 | 10:22 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's probably low on trans fluid. On a hard brake the fluid is sloshing away from the pickup tube.
Old Feb 6, 2008 | 12:31 PM
02sd's Avatar
02sd
Thumbs up
I checked the fluid level a few days ago by taking out the drain plug centre level plug (the torx mini plug) with the truck warm/running in park and some fluid did start to run out, but maybe what I saw is what was in the pipe part of the plug, I should have taken the plug out completely, I will take the plug right out tonight and give it a better chance to leak out, what you say makes sense as I had to top up the trans fluid after we did some work on the cooler lines, Thanks, will keep you posted as to how this works out.
Old Feb 6, 2008 | 06:24 PM
85e150's Avatar
85e150
Still under warranty? Make Ford figure it out.
GADJETFREAK
Jan 25, 2015 03:07 PM
xltrangerflex
Nov 17, 2012 09:52 PM
stangguy61
Aug 2, 2011 06:29 PM
Redrobin52
Jul 31, 2011 09:57 PM
sch02trac
New Member Introductions
Sep 9, 2007 11:15 AM
