msd ignition quit?
Old Feb 6, 2008 | 12:09 AM
gtex's Avatar
gtex
msd ignition quit?
hey guys! sorry it's been so long since I've poked around in here...
so my girls car needs work, and I'm just not interested in working on the sideways V6. So I take the car to the local shop. Now, she's in my 2008 Escape and I'm driving my old truck. I have to go back to the shop twice to get stuff out of her car that she forgot (nevermind I asked her to get anything she needed). On the second trip, i hit a bump leaving the shop and my old truck just quits. I don't have a tool with me, so i get it towed home. Towing guys asked "you're at the shop and you want a tow home?".. and I explain that my truck is very custom, an I was better off working on it. I did not find any busted connections. I'm running an MSD 6AL ignition with an MSD billet distributor. I replaced the magnetic pickup in the dizzy since that has failed before. But, that didn't get the truck running. If I short the magnetic pickup leads, I get a spark out of the coil. but the truck will not run. I might get one combustion when i first hit the starter but nothing more. I want to try another 6al box, but according to the MSD site, if i get a spark by shorting the pickup, then it's working.
I doubt it's fuel related, since it quit so abruptly.
any suggestions?
Old Feb 6, 2008 | 12:29 AM
Hypoid's Avatar
Hypoid
About time you check in!!! :Scolding off:
I agree with two things you have already posted:
1) It's electrical.
2) It's not the MSD module.
I think there is something loose that you have yet to find. I had a coil primary wire slip off it's terminal every time I cam to a stop. Haunted me for weeks, until it stayed off. Another time I parked and listed to the engine miss in perfect rythm with the keys as they swung back and forth.
Have you tried shaking the wires? Take one section at a time, pull, pry, or shake it and try the key.
HTH
Old Feb 6, 2008 | 04:25 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Well I'll be damned , look at what the Cat drug in...LOL.. Good to hear from ya Greg!
And as far as the MSD goes, IF i recall you have had problems with that set-up since day one? Yeah I would think with you saying this happened right after hitting a bump that you just shook something loose?
08 Escalade huh.... what happened with the Jeep? Damn you go thru some rides dude!! LOL...Good to hear from ya!!
RJ
Old Feb 6, 2008 | 07:33 AM
HOTWRENCH's Avatar
HOTWRENCH
Wink Msd
Greg does your MSD box have a Rev Limiter in it?? If it does change the chip out sometimes they will cause the problem you have. ----PS we have had several do this!
Have A Good Day-------Hotwrench
Old Feb 6, 2008 | 07:57 AM
Freightrain's Avatar
Freightrain
Hey Greg! What's up? Nothing good I see.
Ok, you've checked the box and it fires if you cross the leads, then I'd say the box is okay. There is two power wires, main and key. Did you check to make sure both are hot? If box is working it should, but doesn't hurt to confirm connections.
How is the keyswitch plug on back of dash? I had mine come loose and truck shuts off, aburtly. The lock tab was broke off and it would shake loose and quit randomly. I find myself driving down the road and reaching behind to make sure it's tight ocassionaly. Truck would turn over, sorta start and I'd release the key and it would die. Took some time to figure out the cause, and no I don't worry about it IF it happens.
Old Feb 6, 2008 | 02:16 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Have you made the sure distributor is turning?
Wait, that's nothing to laugh at.
Pull the dizzy or put that electronic stuff into another one, and spin it by hand. Do you get a spark?
Bad ground? Anything's possible. Funny that you hit a bump and it quit.
Tow it over another one maybe it'll start?
Glad to gear from you Greg, been a while...
Old Feb 6, 2008 | 08:54 PM
jwtimme's Avatar
jwtimme
when you installed the msd and you used crimp style commectors check the connectors. I fought a bad connection for a week, water had corroded the crimp from the inside could not see it under the plastic cover. Some times that msd stuff is pickey. If I have a weak batterie in my race car it will turn over but won't fire. I carry a spare msd 6a in my truck because I have had it let go several times.
Old Feb 7, 2008 | 10:05 AM
Mike G's Avatar
Mike G
WOW, I'm reaching for my coat 'cause I think we are going to freeze over here.
Welcome back Greg! In order to fix the truck, you need to release the girl who caused it's problem.....
--Mike
Old Feb 7, 2008 | 10:11 AM
gtex's Avatar
gtex
--Mike
yeah, but she's kinda cute, mother to my boy and she ***** like a p@^n star :-) and , as they say, it's cheaper to keep her. although, i"m beginning to wonder.....
Old Feb 22, 2008 | 11:38 AM
gtex's Avatar
gtex
i'm pathetic! it was just the coil. I replaced it with one of these MSD high vibration coils, sinc emine is mounted on teh AC compressor for now. My compressor doesn't work anyway, so I took thebelt off. that shoudl reduce teh vibration. truck is running pretty good. I tightened up all teh exhaust and it sounds nice going through the mufflers like it should :-) I do have a miss, probably a bad plug or wire.
I just managed to get all three vehicles in teh garage for teh first time, with all my tools. pretty awesome. I miss my shop at the old house, but this will work for now.
talk at ya soon,
greg
Old Feb 22, 2008 | 12:56 PM
RapidRuss's Avatar
RapidRuss
Well Greg, we need to see an updated Vid of the truck running? Or a Smokey Burnout!!
RJ
Old Feb 23, 2008 | 08:52 AM
Freightrain
You have to watch what coil you run, as some of those hi power units are for short time use only(ie: drag racing). You'll overheat it and burn it up over time.
We were just discussing this a few weeks ago with buddy's hot rod(600in Mustang). The coil died and he found out that it was truly racing only. With the excessive running time he put on it, it died.
Glad to hear ya got it figured out.
Old Feb 24, 2008 | 12:38 AM
gtex's Avatar
gtex
I initially ran teh MSD Blater coil, then used a locally purchased Accel coil. All high performance, but none I think would be called "racing" coils. Hopefully this "high vibration" MSD coil will last a bit longer.
now I've got a virgin MSD 6AL in a box I need to ship back to Summit, sell or just keep for some future project :-) I ordered it when I ordered the coil. I wanted to figure it that weekend.
I went ahead and ordered new plug wires and another dizzy cap. I still have a miss I need to get rid of.
Old Feb 24, 2008 | 07:52 AM
Freightrain
Ya, those are good, street worthy units. I'm thinking some of the hi-end(ie:expensive) coils that they offer. Buddy found out after the fact by reading the fine print. Good for short runs only(like 5 minutes or less) or it overheats and burns up(like it did).
Old Feb 24, 2008 | 11:18 PM
7d2 Custom's Avatar
7d2 Custom
A "Dizzy?" Aussie or Brit? Those two groups are the only ones I've ever heard of calling a distributor a "Dizzy." Memory whiplash...
