10k mod
no prob,lem jim
hey chaos, you like that arrow? thats some hig tech work right there! and good luck with the switch plan, i drew it up but never tried because of the small difference in power between the sizes. if i were to do it i would have a single position switch, off breaking the circuit allowing the reference signal to go through the icp uninterupted, and on forcing the voltage through the resistor.
Originally Posted by c00nhunterjoe
no prob,lem jim
By the sounds of it, some trucks run better on different setups? im building the breadboard right now, and i guess i make things way too complicated, but i put 4 different levels... stock, 10k ohm, 15K ohm and 20k... we'll see how it works out.
