Head Choices
Old Mar 20, 2001 | 07:58 PM
canuck's Avatar
canuck
Head Choices
Which is better for a prostreet application, the D00E or DOVES?
Terry
Old Mar 21, 2001 | 05:06 AM
cobrajet's Avatar
cobrajet
Head Choices
hi, well i'd go with the D0OE heads. they already have the big valves, screw in studs, guide plates, and you can port them more than you could a set of the D0VE heads. half of your work is already done by the factory. and there rated at 11:3.1 compression. depending on how radical your going you can machine the heads can be shaved and deck the block for even more compression. now unless you have money burning a hole in your pocket, by your self a set of the aluminun heads or the recast blue thunder heads. but if your limited on what to do go with the D0OE-R heads. C.J. later.......
Old May 8, 2001 | 06:52 PM
comet466cid's Avatar
comet466cid
Head Choices
Find some D0OE-R heads. Way bigger ports and valves wicked top end power too. they are SCJ pieces and may be pricey however.
Old May 8, 2001 | 06:55 PM
comet466cid
Head Choices
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
