351 Help?
Old Feb 5, 2008 | 03:40 PM
dazedrodeo's Avatar
dazedrodeo
351 Help?
Will a 351w fit properly on the stands of a 351M? I have a 1976 f150 4x4 with a very weak 351M/400M and a 4spd MT. I was thinking that other than changing the bell it should be a very quick swap.
Old Feb 5, 2008 | 05:02 PM
Kemicalburns's Avatar
Kemicalburns
ive heard they should work but not sure on that. try a search in the engine swap forum. you might also look for some 2wd 302 mounts, since the 351w is the same depth
Old Feb 6, 2008 | 03:34 PM
smoke n tires's Avatar
smoke n tires
351m is a big block bell housing pattern and its mounts are more closely like the 460.
with a 351w you have a small block trans and mounts which are similar to the 302. you might get away with the trans by changing the bell but the mounts im sure would need modification.
Old Feb 13, 2008 | 05:53 PM
classicranger's Avatar
classicranger
On 2 wheel drive trucks they are the same perches as 302 trucks, but i'm not sure on the 4x4. I would think so.
Mongrel
35
Feb 2, 2011 08:55 PM
warecreek
Jan 25, 2006 10:08 AM
351m_torque
Jan 18, 2006 09:03 PM
jec27
Oct 20, 2003 08:32 PM
boss4x4
64
Jul 1, 2002 01:18 AM
