Free 55 update
Old Feb 4, 2008 | 11:16 PM
Free55's Avatar
Free55
Free 55 update
Went to Harbour Freight and bought a sand blaster. Going to clean up the frame, finally found the VIN stamped on the frame. The truck was built in Richmond, VA.
I'll be using 80 grit aluminum oxide. I just read to use crushed walnut shells for body parts. The few parts that need sand blasting is the front grill and its parts and the fire wall.
It's been painted and 3-4 times already, but the body parts and pretty smooth.
Any suggestions?
Old Feb 4, 2008 | 11:23 PM
greythorn3's Avatar
greythorn3
i love harbor freight!!!!!!!
Old Feb 5, 2008 | 03:36 AM
55 f350's Avatar
55 f350
yep a good place for those of us with economically challenged pockets !!!!!!!!! wheres the pics oh free one ???? i dunno beleive i've seen any yet ......
Old Feb 5, 2008 | 04:50 PM
Free55's Avatar
Free55
Yeah I know, seems that I have to place them first on the internet some where then post them through that site.
I'll do it tonight.
Old Feb 5, 2008 | 05:00 PM
cmoritz's Avatar
cmoritz
Free55 , Liquid paint stripper would be my 1st choice,followed by sandpaper/elbow grease, then blast ONLY where nec...but thats my method.Good Luck!!
I like the little siphon feed units for small areas.Good Luck!!
Old Feb 5, 2008 | 06:34 PM
bobj49f2's Avatar
bobj49f2
I'll do it tonight.
Build a gallery on this site, it's free.
https://www.ford-trucks.com/forums/6...-pictures.html
Once you have the gallery set up you can use the images to post here.
Old Feb 6, 2008 | 01:57 AM
Free55's Avatar
Free55
Here's a couple pics.
Old Feb 6, 2008 | 02:05 AM
Free55's Avatar
Free55
And a couple more.
Old Feb 6, 2008 | 02:42 AM
55 f350's Avatar
55 f350
you people out west have got it so good . i know people that would kill to have a truck that nice to start with !! and i thought i had messes around here lol !!!
Old Feb 6, 2008 | 02:23 PM
jon6foot4's Avatar
jon6foot4
if you blast body parts take it easy and tip the blaster down so you're hitting the surface at about a 15 - 20 degree angle to avoid warping. Stop and check the piece periodically to be sure that it is not warping.. especially on a low crown area like the firewall. The grill is has a high enough crown that there is less of a concern there...
I agree with Cmoritz's statement above.
Warping is bad. My two cents...
Old Feb 6, 2008 | 10:50 PM
dongc1's Avatar
dongc1
I blasted my '50 F-1 inside and out with a HF pot. No problem with warping. Keep the pressure at the pot down to about 70 PSI, use the finest sand you can get ( we call it sugar sand), blast at a angle to the surface and keep the nozzle back away from the surface about 8-10 inches. There are some pic in my gallery.
Old Feb 6, 2008 | 11:10 PM
texan2004's Avatar
texan2004
Any suggestions?
Your truck was built in Richmond, CA. The only Ford plant in Virginia was in Norfolk and it was shut down last year some time (perhpas late 2006 - I don't recall exactly). I may be a Texan now but Virginia is home. The Richmoind, CA plant shut down in February 1955 when production was moved to the new Sacremento assembly plant. The Richmond facility was deemed to small to meet the increased production demands of Northern California and the Northern Pacific Coast. The VA/CA mistake is a common one.
Old Feb 7, 2008 | 05:22 PM
53pickemuptruck's Avatar
53pickemuptruck
Looks like you paid too much for that one. Is there any rust? Some people have all the luck.Nice find. Keep us informed of the progress. Keep on Truckin!
Old Feb 8, 2008 | 12:07 AM
Free55's Avatar
Free55
Smile
OH, Richmond, California! That's makes more sense. I too use to live in Richmond, VA. Sucked, but that's just my opinion. Went to school there, great programs.
It's got surface rust behind the grill and it's components. Where the fenders butts up to the cab it's rusty. You know the usual spot way down below. Everything else is pretty rust free.
Old Feb 8, 2008 | 05:41 AM
Last Chance 55's Avatar
Last Chance 55
It will get worse, but please stay the course. Looks great and be gentle as you r storing her up
