Hi All- I know I have seen this subject here not to long ago but I can't find it. I have a 99 F250 SD with the v10 engine. I have 104 k on it. My battery keeps going dead after about 4 weeks. Have replaced the battery three times and it still does it. Alt is puting out 14.8 volts when running. Have used a meter between the unhooked pos. cable and bat. and it shows nothing. What have any of you found if anything?-Bill
Seems that your charging voltage is a little too high. Did you check it at idle? Most alt. the voltage will go up a little when the motor revs up above say 2K RPMs.
Battery Charging - Remember you must put back the energy you use immediately. If you don't the battery sulfates and that affects performance and longevity. The alternator is a battery charger. It works well if the battery is not deeply discharged. The alternator tends to overcharge batteries that are very low and the overcharge can damage batteries. In fact an engine starting battery on average has only about 10 deep cycles available when recharged by an alternator. Batteries like to be charged in a certain way, especially when they have been deeply discharged. This type of charging is called 3 step regulated charging. Please note that only special SMART CHARGERS using computer technology can perform 3 step charging techniques. You don't find these types of chargers in parts stores and Wal-Marts. The first step is bulk charging where up to 80% of the battery energy capacity is replaced by the charger at the maximum voltage and current amp rating of the charger. When the battery voltage reaches 14.4 volts this begins the absorption charge step. This is where the voltage is held at a constant 14.4 volts and the current (amps) declines until the battery is 98% charged. Next comes the Float Step. This is a regulated voltage of not more than 13.4 volts and usually less than 1 amp of current. This in time will bring the battery to 100% charged or close to it. The float charge will not boil or heat batteries but will maintain the batteries at 100% readiness and prevent cycling during long term inactivity. Some gel cell and AGM batteries may require special settings or chargers.
Well you may be leaving something on that just happens to be 3 weeks apart. The regulator usually will charge at 14.5 volts and no more.. I have a special 14.7 volt reg but its for high draw situations. My stock unit was 14.5 and thats with a fully charged battery. Like said above you may be boiling your battery to death. Raise the rpm and check the charging voltage. Try with a load on like high beams. A battery fully charged will read 12.7 volts after a 20 second blast of the headlights to take off the surface charge. How this helps.
