6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
help with charging dead bat
Old Dec 8, 2011 | 04:26 PM
mrteseniar's Avatar
mrteseniar
I have a 06 f350 batteries going dead during start up no battery light when you turn the key batteries are new alternator rebuilt and tested some times no charging could come from the exciter wire or battery light
Old Dec 8, 2011 | 05:43 PM
aquaman's Avatar
aquaman
I haven't looked at mine, so this might not apply, but is the field winding getting power? No field winding power = no alternator output
Old Dec 8, 2011 | 07:49 PM
senix's Avatar
senix
time for a new...or a warranty claim on the rebuilt alternator.
Old Dec 9, 2011 | 07:17 AM
mrteseniar's Avatar
mrteseniar
The alternator is charging most of the time. Some time between when the glow plugs come on with no charge then back off. there is not enough voltage at batteries to the exciter wire to open up the regulator so it will start charging. Should battery light come on when the key is turned on. Bc i have no battery light.
Old Dec 9, 2011 | 04:32 PM
aquaman's Avatar
aquaman
How many volts are at your battery when the truck is off, and what does it measure when the truck is running? Were the batteries fully charged before trying to start?
Those glow plugs suck a lot of juice, so if the batteries were weak to begin with, they'll just flatten the battery a lot sooner.
Old Dec 9, 2011 | 06:58 PM
slowmans's Avatar
slowmans
glow plugs will also stay on for up to 2 minutes after you start the truck....
Old Dec 10, 2011 | 11:23 AM
mrteseniar's Avatar
mrteseniar
yes batteries have 12.8 v the charge light does not come on when the ignition is on all other warning lights come on taking dash apart to get two battery warning light to see why it does not come on rebuilt alternator and tested!!! batteries charged and tested
exciter wire maybe sorted some of the time please respond
Old Dec 10, 2011 | 03:40 PM
Gearitis's Avatar
Gearitis
If you change batteries, change both, do not just change one. Your batteries are only as good as the "worst" one.
Old Dec 19, 2011 | 04:14 PM
mrteseniar's Avatar
mrteseniar
does anyone know were the green and red strip wire from the alternator go
jkiser01
Aug 20, 2021 12:20 PM
Tym
Oct 14, 2018 09:08 AM
Dirtmetal
Mar 28, 2011 06:21 PM
npccpartsman
Escape & Escape Hybrid
13
Jan 10, 2011 09:08 AM
dieseldrivr
Jan 25, 2010 10:41 PM
