Sponsored by: Real Truck
Dead Battery Again!!!
Old May 3, 2004 | 04:29 AM
willbill28's Avatar
willbill28
Question Dead Battery Again!!!
I have a '99 F250 with a 7.3L Powerstroke. The driver side battery was dead so i replaced it. The stock guage shows it is charging, but two days later the new battery was dead. I recharged it left the truck run for about 10 minutes showing it was charging. Today the new battery is dead overnight from just sitting. Any suggestions????
Old May 3, 2004 | 05:32 AM
slc10844's Avatar
slc10844
I have an 03 and it has run-down protection, that automatically turns off power to anything causing current draw (i.e. lights, power port, etc). I imagine your vehicle has the same feature. Purhaps there is a failure of whatever controls that circuit or maybe you bought a defective battery.
Old May 3, 2004 | 11:26 AM
daimon1054's Avatar
daimon1054
You have a short somewhere, go have it checked. A quick test is to pull the positive cable, put a volt meter om the bat pos and the cable end, if you read volts you have a current draw. You can start pulling fuses one at a time till it goes away and that is the short, if the short is after the fuse.
Old May 5, 2004 | 02:07 PM
Bruce1026's Avatar
Bruce1026
The batteries in these trucks are in paralle, meaning they are being charged and discharged at the same time. If on one is being discharged I wonder if the battery cables are good and the connections are clean. Also check the ground for the alternator and batteries at the engine or chassis. I had an explorer that they replaced the battery and the alternator at the dealer for the same problem and found that it was a dirty connection at the block that was not allowing it to charge fully. Cost Ford about $400 to find that out (all under warrenty).
72camperspecial
May 28, 2013 09:12 PM
mrteseniar
6.4L Power Stroke Diesel
Dec 19, 2011 04:14 PM
Bpayton
Sep 19, 2011 07:36 AM
a ayala
May 6, 2010 09:29 PM
Cold_Steel
Nov 21, 2007 11:43 PM
