Inline fuel pump
Old Feb 4, 2008 | 05:16 PM
snubber's Avatar
snubber
Inline fuel pump
I always had to crank my truck for a while to get it to start when it is cold.
I have changed quite a few things, but it is still almost the same. I dieselmech. told me I could have a internal leak in the injectorpump. He told me that I could try an electric inline fuel pump, he new there was some witch stayd on only 12 sec. everytime you turned on the ignition. He colud not remember the name of it, and I have been looking on the internet, with no luck. Anyone of you guys heard of something simular to this pump?
Old Feb 4, 2008 | 06:20 PM
Olytlr's Avatar
Olytlr
Does it start okay once it's warmed up?
Old Feb 4, 2008 | 06:25 PM
snubber's Avatar
snubber
Yes, no problem then.
Old Feb 20, 2008 | 12:34 PM
Foxxx's Avatar
Foxxx
mine has this issue too, does any one have any recommendations as to what pump to use?
Old Feb 20, 2008 | 01:52 PM
j-redsjeep's Avatar
j-redsjeep
allot of guys use and reccomend a holley red pump, makes changing fuel filters much easier to. a simple chevy block off plate can be used for where the mechanical pump was to.
Old Feb 20, 2008 | 02:46 PM
fuzzy1626's Avatar
fuzzy1626
Cold start problems are usually glow plug related or air intrusion of the fuel system.
Old Feb 21, 2008 | 12:40 AM
Redneck-Cowboy's Avatar
Redneck-Cowboy
How does it start or attempt to start?
Crank and fire up, then die, then long crank= lift pump or some air somwhere getting in the system
Crank and crank and crank and kinda fire= check ur glow plugs
How long is ur wait to start light staying on?
Old Feb 21, 2008 | 05:08 PM
AndysFords's Avatar
AndysFords
Yeah, a lot of people will name injection pump when its glow plugs. These engines are far more sensitive than other brands about glow plugs. I also have a small fuel pump on a toggle switch, I turn it on when I change fuel filters.
Boodrow379
Apr 24, 2014 09:24 AM
e6ug
13
May 25, 2013 10:26 PM
FordmanShane
Jun 7, 2011 08:01 AM
Ed 4X2X
May 11, 2006 10:33 PM
Cruiser11
1983 - 2012 Ranger & B-Series
13
Jun 15, 2004 04:04 PM
