97 F350/ 460
Old May 29, 2001 | 01:57 PM
tmyers's Avatar
tmyers
97 F350/ 460
Old May 31, 2001 | 09:07 PM
dano0580's Avatar
dano0580
97 F350/ 460
have 97 F350 with a 460 now getting 9to 10 mpg, when towing a trailer
It drops to about 6to7 mpg need any help to get better mpg.
Also I,m thinking about dropping a power stroke in any coments ?
how much trouble is this going to be to swap
Old Jun 1, 2001 | 06:38 AM
Nathan's Avatar
Nathan
97 F350/ 460
That sounds very close to what my 95 F350 gets with C6, 3.55 R&P. If you must get the PSD, trade in your truck for one with it, the changeover would be very involved!
Nathan
Old Jun 1, 2001 | 05:19 PM
jim henderson's Avatar
jim henderson
97 F350/ 460
I have a 94 F250 4x4 supercab 460 E4OD and 4.10 gears so it should be failry similar to the 350, a bit lighter I think. I tow an 8,000 pound trailer and get 9-10 mpg if I am good and I have seen 6mpg in really hilly terrain.
Assuming your truck is stock, your mpg is within range, but a little on the low side, considering the extra weight and more drivetrain drag of a 350. If you have bigger than stock tires, you may be lugging the engine and loosing mileage. A very common mistake since fat big tires are popular for looks but can adversely affect towing performance.
I heave read that the Ford trucks with 460 have restrictive exhaust and benefit a lot from headers, freeflowing mufflers and pipes. Also read that the Jacobs ignition or the MSD have helped mileage a few mpg.
May be worth looking into an RV cam.
Good Luck,
Jim Henderson
Old Jun 1, 2001 | 08:50 PM
Nathan's Avatar
Nathan
97 F350/ 460
>Also read that the
>mpg.
>RV cam.
>Good Luck,
>Jim Henderson
Just my opinion, DO NOT GET A JACOBS IGNITION SYSTEM!! I put a Jacobs Pro Street system on my F350. No power gains and mileage went DOWN! Put it on my 79 351M and now have a miss between 1900 and 3000 RPM. Its going back to Jacobs if for no other reason than to get rid of it! Dont waste your money like I did.
Nathan
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
